      05-31-2011, 12:30 AM   #1
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
shudder while accelerating with DSC OFF...
ive got 57k on it right now.
while at the bear mountain run this sunday I began noticing shuddering and knocking type sounds comming from below me when ever i slammed the gas....sounded like it was comming from below me, i could not tell if it was in the front or the rear. feels something not rotating right. drive shaft? guibo? maybe the recent clutch flywheel oem replacement install was bad? idk...
I enjoy dsc off from light to light in the city but after running her hard around the twisties and staying with that GTR around the corners of Bear mountain area this started comming about. any advice?
Im gonna check if I melted of those poly urethane motor mounts from UUC....
IDK
      05-31-2011, 09:12 AM   #2
arggg45
No_Country
11
Drives: fairly quickly.
IDK
Was it constantly making this shuddering noise or was it just when you 'slammed' the gas going around a corner.
"It will not have enough power until I can spin the wheels at the end of a long straight in top gear."
-Mark Donohue
      05-31-2011, 09:38 AM   #3
Z4-VILLA
Afghanistan
111
only under hard acceleration with dsc off and you can reall hear if i got wheels turned and im going for it
      06-01-2011, 10:47 AM   #4
Z4-VILLA
Afghanistan
111
can smeone please help?
      06-01-2011, 10:55 AM   #5
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Doesn't sound like a common problem, thats why you don't see many people helping. Is it doing it with traction control on?
      06-01-2011, 11:01 AM   #6
Z4-VILLA
Afghanistan
111
just hard acceleration dsc on or off....maybe I didnt break the clutch in properly...smdh...its been 500 miles though since clutch and flywheel replacement with oem parts.....idk
      06-01-2011, 11:03 AM   #7
ZStig
279
Sounds like something a tech would figure out (as long as he's not Russian). lol
      06-01-2011, 11:36 AM   #8
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
So, only with DSC off? Perhaps some wheel hop or loss of traction? It's curious it doesn't happen with DSC on. Straight line at speed (60 plus) with good traction I'd expect any drivetrain issues to be present with or without DSC on at WOT. At lower speeds, especially in corners or over bumps, it may be some loss of traction. :
      06-01-2011, 11:40 AM   #9
arggg45
No_Country
11
if its from the rear, it sounds like your diff isn't locking properly, but you could also be causing it by slamming on the gas instead of smoothly rolling into it...
-Mark Donohue
      06-02-2011, 03:22 PM   #10
Z4-VILLA
Afghanistan
111
just got told by mechanic (same shop that did all my mods btw...Motorcepts in Richmond hill, NY) that it is the u- joint at the diff
      06-02-2011, 04:34 PM   #11
ZStig
279
sounds like a relatively simple fix
      06-02-2011, 06:09 PM   #12
Z4-VILLA
Afghanistan
111
true now to find the hardest u joint available? i have no idea
