      05-22-2011, 02:19 PM   #1
vicj
vicj's Avatar
Drives: '06 M Roadster; 2010 Mini
Exhaust and seal rings question
When installing new mufflers, MUST one use new seal rings? If the old rings look like they are in great shape, can you just re-use them, or will that create small leaks, because they've been "shaped" over time in the old exhaust flange...?
Thanks
      05-22-2011, 02:38 PM   #2
r4gs
Viper Driver
Singapore
36
Drives: F-16
i re-used the 'seal' ring and tightened the bolts securing the two flanges according to desired muffler positioning. no leaks whatsoever and about 6,000 miles now and no re-tightening of any bolts of any kind needed.
      05-22-2011, 09:08 PM   #3
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Pretty much only gaskets and donuts need to be replaced. Everything else should be re-usable for the life of the car (for the most part...).
      05-27-2011, 07:22 PM   #4
vicj
vicj's Avatar
Does anyone have "before and after" pictures of the exhaust flanges? I can't be positive, but I'd swear my flanges were completely flush with the stock exhaust, and now there's about a quarter inch gap after installing the Stromung. Almost as if the Stromung feed tube doesn't quite fit the seal ring perfectly.
If anybody has those sorts of pics, I'd love to see.
