      08-22-2016, 12:05 PM   #1
RADRACR
RADRACR's Avatar
Question Strange idle behavior under specific conditions.
Firstly, this is not about the tired discussion of the random stall that all S54s seem to have.
1) When cold (within 5 minutes) engine drops RPMs and nearly stalls at the moment the accelerator is pressed. 90% consistent every morning after waiting for the community gate to open to drive out. After that one occurrence, the rest of the drive is fine. This is different than the more common issue of randomly stalling when cold unrelated to accelerator.
2) After turning on A/C, idle becomes irregular. Very subtle. Can barely see the tach move but I have aftermarket exhaust and can hear it. The issue remains after turning off A/C. But starting the car WITHOUT A/C is fine until I turn A/C on again.
I've been reading about the ICV (idle control valve)? What do you think?
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      08-22-2016, 03:10 PM   #2
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Any codes?
she’s home! '22 M4 Comp xDrive
      08-22-2016, 03:23 PM   #3
RADRACR
RADRACR's Avatar
I don't have a device to check. No CEL.
      08-22-2016, 03:49 PM   #4
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Might be able to have Autozone etc. check codes for you. I had a similar situation a few months ago with a rough idle and near-stalls, and I had codes for over/under voltages across several control modules. No CEL either (except the couple times it actually stalled...). Turned out to be my voltage regulator on the alternator, around 60k miles at the time IIRC.
Could be something similar, could be totally different, codes are a good place to start GL
      08-24-2016, 09:46 AM   #5
F360C
Drives: E86 S54
I had some weird idle issues with my car also... replaced the voltage regulator on the back of the alternator and all is fine now. You can get the part off ebay for $60 and it takes about an hour to swap out.
Other causes could your MAF, O2 sensors, very dirty airfilter or maye a vacuum leak somewhere in the engine bay. Grab a beer, flash light and have a good solid look around the engine bay. Gently move/tug lines and wires/hoses/lines to make sure everything is still connected.
07 Z4 M Coupe AW/IR
      08-24-2016, 11:24 AM   #6
angelr
Drives: 07 aw/ir m coupe, 2013 S4
Would you happen to have that part number handy?
      08-24-2016, 12:11 PM   #7
F360C
Drives: E86 S54
http://www.ebay.com/itm/NEW-VALEO-OE...STRK:MERFB:IID
07 Z4 M Coupe AW/IR
      08-24-2016, 12:58 PM   #8
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
^^ pretty sure I bought the same one too, sure as hell beats buying a new whole alternator
      08-24-2016, 01:02 PM   #9
angelr
Cheers!
      08-24-2016, 01:08 PM   #10
RADRACR
RADRACR's Avatar
Now my ABS, Brake, and DSC lights are coming on and off intermittently. Radio cuts in and out. Certainly seems electrical related. Will try this voltage regulator.
      08-24-2016, 03:16 PM   #11
StickMon
StickMon's Avatar
Drives: 2006 MR
How old is your battery?
      08-24-2016, 04:52 PM   #12
RADRACR
RADRACR's Avatar
Original!
      08-24-2016, 07:25 PM   #13
StickMon
StickMon's Avatar
Drives: 2006 MR
My car got similarly wacky and ultimately went into limp mode claiming the TPSs were broke.
Replaced 5 year old battery. Problem solved.
      09-02-2016, 03:50 PM   #14
RADRACR
RADRACR's Avatar
Thumbs up
1) Replaced OEM battery with Napa 9848. No effect to my issue but I'm not upset about it as it needed replacing regardless.
2) Changed Voltage Regulator. Drove to and from work today in 100 degrees with A/C on -- so far so good. But goddamn was it a PITA getting that alternator in and out. Evidently those bolts are only cosmetic.
I imagine lots of folks replace the whole alternator when only the cheap plastic regulator is bad. It would seem the alternator itself is a more robust piece of equipment.
Does not solve issue #1 in my OP. ICV still?
Anyway, thanks A TON to this forum. Saved my ass.
      09-06-2016, 02:32 PM   #15
StickMon
StickMon's Avatar
Drives: 2006 MR
Originally Posted by RADRACR View Post
... Evidently those bolts are only cosmetic. ...
After finally prying mine out, I filed it down a little bit to make it easier to get back in.
Still had to pound it in with a mallet. Makes it fun to get the holes lined up so the bolt will go through.
      09-06-2016, 07:55 PM   #16
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
I'm pre-ordering one of these voltage regulators. It's only a matter of time.
