12-27-2011, 08:57 PM | #1 |
floor sweeper
Rep 47
Heated Seats Install
I installed seat heaters this past weekend - following roughly the same procedure as I did in my Toyota Tacoma a few years back and thought I'd share a few pics of the tear-down and install.
The patient prepped for surgery - battery charger installed so I could leave the doors open. On the bench and ready for disassembly Most manufacturers follow similar techniques - hog rings, hog rings, and more hog rings Take your time. The seat actuators look complicated, but everything has a place. Passenger seat (the black felt is the airbag sensor) test-fitted with the heating pad. "X" section will be cut and removed. Hog ring pliers are mandatory. This is the 8th seat for this trusty pair of pliers. These are the old rings from just one seat! I've always thought the seat bolster felt a little flimsy compared to the other side. This is why. The seat foam was deformed from the factory and very thin. I built it up using some scrap foam and poly quilting material - better than new. I also used a similar process in other areas in order to restore most of the effects of natural leather stretching - these seats have 54k miles on them. Mounting the switches - I like a factory look and I'm cheap. The shifter surround is easily replaceable if I make a mistake. The cables in the photo look like they're part of the shifter - they're actually part of the welder in the background. All done and buttoned up. All wires are hidden in the console - 12v is direct from the battery and grounded via a self-tapping screw under the shifter surround. These heaters seem to heat faster than those I've used previously - hot in under 4 or 5 minutes and so hot you have to switch to low after 10 minutes or so. |
12-27-2011, 09:27 PM | #3 |
Rep 556
Drives: 2003 ESS TS1 Z4
Very nice! Wish i could have bolsters on my seats! Haha
12-28-2011, 10:30 AM | #7 |
Rep 12,567
Wow nice install indeed!
Btw just noticed the yellow rectangle side reflectors - you have a 3.0si with M wheels, what size tires are you running? Any rubbing? |
12-28-2011, 11:42 AM | #8 |
floor sweeper
Rep 47
Stock fronts - 225/45r18 and one size down in the rear - 245/40r18. No visible marks, but they've rubbed a time or two - Ohio freeway expansion joints can be hellacious.
12-28-2011, 05:42 PM | #9 |
Rep 12,567
Nice - you should black out those sidemarkers with plastidip, I bet it'd look really great!
12-29-2011, 10:24 AM | #11 |
instagram 997turbotom
284
Rep 7,377
it would be a completely wrong texture
12-29-2011, 10:35 AM | #12 |
Rep 12,567
Yea but when would you ever feel it? Would rather do a 5 min job than have to take them off, sand down and spray. Plus at least it wouldn't be permanent. Only downside is it'd be more matte than glossy but still not as noticeable as the stock ambers.
12-29-2011, 11:29 AM | #13 |
284
Rep 7,377
It would look completely off, thats what I'm saying. Flat and rubbery vs black and glossy. Might as well just buy black shiny plastic paint
12-29-2011, 02:22 PM | #14 |
First Class M
20
Rep 217
Drives: Z4M Coupe, E36 Coupe
I cant do a such something like that I would damage everything anyway well done
'07 Z4MC l Alpine White l Supersprint Race Exhaust l Supersprint X Pipe l OEM Carbon fiber Spoiler l H&R Springs l Vossen VF051 l G-Power SK I 415 rwhp l RPI Scoop l ///M Performance Knop. |
12-29-2011, 02:34 PM | #15 |
Rep 847
Great execution and very clean. For those who want a more OEM look, the console switch bar with heated seat buttons is usually available on ebay for under $50. This setup looks as good if not better though.
12-30-2011, 09:26 AM | #16 |
floor sweeper
Rep 47
I looked into this first as like you say the panels are between $50 and $75, as I would've preferred the look of the factory switches. However those (I think) are wired back to a controller of some sorts - each press of the button results in a different heat setting and then finally turns the heaters off again. An aftermarket setup requires a latched switch with a specific setting for off/high/low.
01-04-2012, 07:17 PM | #17 | |
Rep 659
Garage List 2022 M5CS [0.00]
The installation looks awesome, nice work!!
