      12-13-2011, 09:07 AM   #419
Beedub
Originally Posted by Roffle Waffle View Post
Never heard of anyone having to tune their car for the racelogic system...
I'm not running stock programming. Guess I'll ask ESS what they think. I'm months away from that anyway, I'm saving up for a vacation
he's 100% correct, the turbo m3's that use pro-efi use a similar traction setup, they throw muliple CELs everytime the t/c cuts in, and a good amount of those cause limp mode.....
hmmmmm just thought, pro-efi has now made a plug and play ecu for the z4m....imagine the benefits of having a standalone ecu, flexfuel capability, proper traction and launch control :-)
      12-13-2011, 09:25 AM   #420
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Didn't you just say that the TC on the pro-efi causes trouble? Or you think thats been fixed on the z4m?
On the racelogic website, their sample video is of a stock looking z3m roadster
      12-13-2011, 10:34 AM   #421
Beedub
Afaik they fixed the issue on the z4m......
      12-13-2011, 04:44 PM   #422
ZStig
279
You think we'd need to go back to using a MAF sensor for the pro-efi?
      12-14-2011, 02:24 AM   #423
Beedub
yes i think we do :-( not quite sure how that would work?? then again the pro-efi is about as good as it gets, if the stock dme can do alpha n im certain the pro efi can as well... the benefits of pro-efi are huge..... and add flex fuel, traction control to the equation we talking a different ball game, this is the only standalone we have a proper plug and play harness for i think........
Ive been waiting for that HPF z4m to surface for AGES, HPF posted up links to the car but sadly it seems they cant get it running at the moment?? id love to know the hurdles they are approaching.............
someone on e46fanatics ran a stock s54 upto 700+ WHEEL HP for some time to destruction test the motor, i was fankly amazed it last so long, 30+ drag passes, Loads of motorway pulls.......... Its the german 2jz ;-) lol i the end it finally threw a rod after months of abuse.... this is on an 80k mile car BTW!! Very impressive.
what was up with the meth kit??
      12-15-2011, 10:15 AM   #424
ZStig
279
really interesting info about the s54's endurance....
I've had my rear camber adjusted from -2.5* to -1.6*. Since its very cold outside I haven't had a chance to test the increased off the line grip, but its gotta be there.
I'm still struggling with my wierd electrical gremlin, where a few warning lights randomly flicker and the radio shuts off for a few seconds. I've removed my ambient temp sensor which I thought was causing problems, but now I'm gonna try removing the radio headunit which I should have tried a while ago.
I don't want to play with the meth until this is solved. I tackle one issue at a time
I really want to do some 60 -130 pulls but I'm intimidated by the idea of doing it on public roads...
      12-16-2011, 06:46 AM   #425
Beedub
can the stock rear camber be changed upto -2.5?? thats alof adjustability for a stock setup, good info...
Re the electical gremlin are you thinking its anything to do with the s/c install or completly unrelated??
      12-16-2011, 12:05 PM   #426
ZStig
279
The H&R springs naturally give you some additional negative camber, thats why I was able to go -2.5
don't know where my electric thing is from....
      12-18-2011, 05:00 AM   #427
Beedub
btw my tuner told me that vt2-550 WILL be released for our cars shortly :-)
i cant help but think it will be getting to the realm of unuseable however in the z4m.....
for us 500 guys its only a few light mods and a new tune....
      12-18-2011, 12:15 PM   #428
ZStig
279
that sounds fantastic!
but I agree about the platform's traction bottleneck... I'm thinking all boosted s54s need to be running Viper sized rubber in the back to lay it down. The good news is that even though the Volk TE-37 only goes up to 10.5" wide, you can run 315mm rubber back there. Only issue is the additional cost. I'd REALLY like to do something like that in 2012. Nothing crazy in terms of bodywork, JUST enough to fit that in
In terms of my electric, its not my radio, but I'm beginning to think its my front throttle position sensor again, based on the kinds of warning lights its flashing. I'm gonna drop the car off at a shop and have them figure it out, I'm out of trial and error ideas
      12-18-2011, 02:23 PM   #429
Beedub
i honestly think you should try and proper road legal slick, im willing to bet it will be more than enough even in 265 section form..........
      12-18-2011, 06:44 PM   #430
ZStig
279
yeah but this is my 16k mile a year daily driver...
      12-19-2011, 04:59 AM   #431
Beedub
true............ i forget that small fact ;-) cant lie, id LOVE to fit some FAT rubber in the rear, as the arches are just stick/bolt on, it would be nice to buy some brand new ones and take them to a proper metal panel beater and have them properly massaged out... i think it would look insane.
      12-19-2011, 11:00 PM   #432
ZStig
279
no need for fat rubber, just need heat in those tires and roll into it launching at 1000rpm, and -1.5* camber on the rear. 44*F weather. There is more left in this car, I shifted into 2nd at only about 7500
(no complete 60-130s)
I'm EXTATIC to get 0-60 in 4.2s. That was my goal with this car, to match my old 1999 Viper GTS' 0-60. Just gotta get the 0-100s lower
      12-20-2011, 03:15 AM   #433
Beedub
Fuckkk 4.2!!!! Thats proper fast!!! I reckon 3.9s with a good launch and using all the revs!!
well done roff!!! very well done!! adding boost to these cars throws them into a complete new category..... btw your 0-100 isnt to shabby either!! you should be EXTREMELY happy with those figures....... forget vt2-550, lets just loose alittle weight imo!!!
      12-20-2011, 09:15 AM   #434
ZStig
279
I'm very very happpy. Now I don't feel the need to spend thousands on that racelogic box or wide rear tires and modified fenders. At least for these power levels...
I noticed the road I ran goes up a slight incline after the 60mph section, so Im gonna find a flatter one for this.
      12-20-2011, 09:56 AM   #435
Beedub
Great for someone to finally post some performance figures for our cars, wish i had access to a vbox :-(
Now find a flat stretch, use all 8k revs and lets see some high 3s....
      12-20-2011, 10:00 AM   #436
ZStig
279
Count me in
      12-20-2011, 10:41 AM   #437
ZStig
279
FYI, I was quoted ~$1500 for the labor to flare out the rear fenders while following the body lines, plus paint, in order to fit 10.5s in the back. For now I apparently don't need it, and will instead buy and install a linelock system so I can do reliable burnouts to warm up the tires =) =)
      12-20-2011, 12:59 PM   #438
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
awesome 4.2!
///M - Some Mods 'N Stuff
      12-20-2011, 01:28 PM   #439
ZStig
279
Didn't think this car had it in her on street tires =)
beedub was right. Too bad its gonna be wet around here for a week. I want to crack the 4.0 mark
      12-20-2011, 02:02 PM   #440
Beedub
with the extra 500 rpm and squeezing every last drop of boost id wager you hit straight 4s or even less!!, dont discredit yourself.... this car is NOT easy to extract those type of numbers from especially with the blower, its definatly a balance of controlling the throttle, metering out slip and good shifting....
some 0-60s robbed from another site, excuse the messy look!!! pat your cars bonnet.... shes punching well above her weight.
just to make you feel even more smug!!! SAME as a 997 gt3 rs and v10 gallardo!!! And you dont have 4wd...... !! Now please get out and get us into the Porsche Turbo times!!!
Chevrolet Corvette Z06 3.7s
Pagani Zonda C12 S 7.3 3.7s
Porsche 959 3.7s
Ruf R Turbo 3.7s
Ferrari F40 3.7s
Melling Wildcat 3.7s
Lamborghini Diablo 6.0 3.8s
Radical SR3 3.8s
Chevrolet Corvette Callaway C16 3.8s
Maserati MC12 3.8s
Ford GT 3.8s
Brabus Bullit 3.8s
Caterham 7 Superlight R400 3.8s
Mercedes-Benz SLR McLaren 3.8s
Mercedes-Benz SLR McLaren Roadster 3.8s
Pagani Zonda Roadster 3.8s
Koenigsegg CCR 3.8s
Lamborghini Gallardo Superleggera 3.8s
Dodge Viper SRT10 ACR 3.8s
Porsche 911 Turbo 996 3.9s
Noble M12 GTO-3R 3.9s
Porsche Carrera GT 3.9s
Audi R8 V10 3.9s
Caterham 7 CSR 260 3.9s
Tesla Roadster 3.9s
Porsche 911 GT3 RS 4.0 997 3.9s
Ferrari F430 3.9s
Ferrari California 3.9s
TVR Cerbera 4.5 3.9s
Wiesmann GT MF5 3.9s
Mitsubishi Lancer Evo IX FQ360 3.9s
Noble M12 GTO 3.9s
TVR Tuscan S 3.9s
Lotus Exige 240R 3.9s
TVR Sagaris 3.9s
Porsche 911 Turbo 993 3.9s
Ferrari 360 Challenge Stradale 4.0s
Aston Martin V12 Vantage RS 4.0s
Dodge Viper GTS 4.0s
Porsche 911 Turbo 997 4.0s
Porsche 911 GT2 996 4.0s
Chevrolet Corvette 4.0s
TVR Cerbera 4.2 4.0s
Ford Shelby Mustang GT500 4.0s
Ruf CTR Yellow Bird 4.1s
Ferrari F430 Spider 4.1s
TVR Chimaera 5.0 4.1s
Cadillac CTS-V auto 4.1s
Cadillac CTS-V Manual 4.1s
Ascari KZ1 4.1s
Lotus Exige S 4.1s
Lamborghini Gallardo Spyder 4.2s
Ferrari 575M Fiorano 4.2s
Morgan Aeromax 4.2s
Lotus Espirit V8 4.2s
Aston Martin DBS 4.2s
BMW M6 E63 4.2s
TVR Tamora 4.2s
Audi R8 V12 TDI 4.2s
Alfa Romeo 8C Competitizione 4.2s
Porsche 911 GT3 RS 997 4.2s
Lamborghini Gallardo 4.3s
Bentley Continental GT Speed 4.3s
Aston Martin Vantage 600 4.3s
Ferrari 612 Scaglietti F1 4.3s
Ferrari 550 Maranello 4.3s
Ford Gurney Signature Edition Mustang 4.3s
Porsche 911 997 GT3 4.3s
Audi RS6 Avant 4.3s
Ferrari 360 Modena F1 4.3s
Audi R8 4.3s
Subaru Impreza STI Type RA Spec C 4.3s
Mercedes C63 AMG 4.4s
TVR T350T 4.4s
Mitsubishi Lancer Evo VIII MR FQ-340 4.4s
Aston Martin V12 Vanquish 4.4s
Mitsubishi Lancer Evo VI GSR 4.4s
Mercedes-Benz S65 AMG 4.4s
Mercedes-Benz CLS 63 AMG 4.4s
Mercedes-Benz CL65 AMG 4.4s
Porsche 911 996 GT3 RS 4.4s
Subaru Impreza STI 330S 4.4s
Bentley Continental GTZ Zagato 4.5s
Bentley Continental GTC Speed 4.5s
Holden HSV GTS Supercharger 4.5s
Mercedes-Benz S63 AMG 4.5s
Mitsubishi Lancer Evo VI RS 4.5s
Lotus 340R 4.5s
Mercedes-Benz CL 600 Coupe 4.5s
Porsche 911 GT3 996 4.5s
Mitsubishi Lancer Evo IX FQ-320 4.5s
Audi RS6 4.6s
Dodge Viper SRT/10 4.6s
Wiesmann GT MF4 4.6s
Lamborghini Countach LP5000S QV 4.6s
Jaguar XKR 4.6s
Porsche 911 Carrera 996 4.6s
Nissan Skyline R34 GTR 4.6s
Aston Martin V8 Vantage 550 4.6s
Lotus Elise S2 Sport 190 4.7s
Ferrari 355 F1 Berlinetta 4.7s
BMW Alpina B5 E60 4.7s
BMW M5 E60 4.7s
Mitsubishi Lancer Evo VII GSR 4.7s
Bentley Continental GTC 4.7s
Porsche Cayenne Turbo 4.7s
Caterham 7 Superlight R300 4.7s
Audi RS4 4.7s
Mercedes-Benz CLS 55 AMG 4.7s
TVR T350C 4.7s
TVR Griffith 4.3 4.7s
Jaguar XFR 4.7s
Vauxhall VX220 Turbo 4.7s
Cadillac STS-V 4.7s
Bentley Continental GT 4.7s
BMW M3 E46 4.8s
BMW Z8 4.8s
Aston Martin V8 Vantage 4.8s
Aston Martin Vanquish S 4.8s
Porsche 911 Carrera S Cabriolet 997 4.8s
BMW Alpina B7 E65 4.8s
BMW M3 Coupe E92 4.8s
Ferrari 512TR 4.8s
BMW M6 Convertible 4.8s
Mitsubishi Lancer Evo VI Tommi Makinen 4.8s
Subaru Impreza RB320 4.8s
Maserati GranSport 4.8s
Audi RS2 Avant 4.8s
Dodge Charger SRT8 4.8s
Mercedes-Benz E55 AMG 4.8s
BMW Z4 M Roadster 4.8s
Audi RS6 4.8s
Farbio GTS 4.8s
BMW Alpina B3 Biturbo 4.8s
TVR Griffith 500 4.8s
Lotus Exige S2 4.9s
Chrysler 300c SRT8 4.9s
Aston Martin V8 Vantage N400 4.9s
Maserati Granturismo S 4.9s
BMW M5 E39 4.9s
Subaru Impreza P1 4.9s
Ferrari 512TR 4.9s
Audi RS4 Cabriolet 4.9s
Lexus IS 350 4.9s
MG XPower SV-R 4.9s
Lotus Carlton 4.9s
Mercedes-Benz SLK 55 AMG 4.9s
Aston Martin V8 Vantage Roadster 4.9s
Lotus Europa SE 4.9s
BMW M3 E90 Saloon 4.9s
Maserati 4200 GT 4.9s
Vauxhall VXR8 4.9s
BMW M3 CSL 4.9s
Lexus IS-F 4.9s
Ferrari 288GTO 4.9s
Mazda RX-7 FD 4.9s
Jaguar XKR 4.9s
Lotus Evora 4.9s
Bentley Brooklands 5.0s
Subaru Impreza 22B STi 5.0s
Ford RS200 5.0s
Mitsubishi Lancer Evo X RS 5.0s
Audi S5 5.0s
Maybach 57S 5.0s
Aston Martin DB9 5.0s
Subaru Impreza RB5 5.0s
BMW Alpina Z4 Roadster S 5.0s
Nissan Skyline R33 GTR 5.0s
Jaguar XJR 5.0s
Maserati Quattroporte 5.1s
Maserati Quattroporte Sport GTS 5.1s
Lotus Elise S2 111S 5.1s
BMW Z4 M Coupe 5.1s
Vauxhall Monaro VXR 6.0 5.1s
Audi S6 5.1s
BMW 550i M Sport 5.1s
Audi S8 5.1s
BMW Z4 sDrive 3.5i 5.1s
Subaru Legacy 2.5GT spec. B 5.1s
Lotus Esprit GT3 5.1s
Porsche 911 Carrera 4S 996 5.1s
Toyota Supra 5.1s
BMW E86 Z4 M Coupe 5.1s
Maserati 3200GT 5.1s
Mitsubishi Lancer Evo VIII GSR 5.1s
Ferrari 456M GT 5.2s
TVR Chimaera 4.5 5.2s
Maserati Ghibli Cup 5.2s
Subaru Impreza Turbo 5.2s
Aston Martin DB7 5.2s
Aston Martin V8 Vantage 5.2s
