09-01-2010, 07:06 AM | #23 |
Rep 2,138
Drives: Me
No I don't see any reason you can not piece this out. Just get the proper size/thread grade 10.5 bolts (stronger the better) and washers. Mic out the washers to get each washer pack the same thickness.
09-01-2010, 05:09 PM | #24 |
Rep 632
Thanks man - hey, regarding the HPDE at NCCAR, I was thinking of maybe trying to make it. Don't have a helmet, would need an inspection, and I'm out of town until Tuesday - have you heard anything more about it? I like the idea for a first time for me - flat, open, constant radius curves, might be a great place for the first HPDE. Just curious.
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
09-01-2010, 05:35 PM | #25 | |
Rep 2,138
Drives: Me
It's an Asphalt Adventures event. Never been there since it's so new. I am hoping it's a good track. It's closer than VIR. |
09-07-2010, 01:08 PM | #26 |
Rep 11,667
Picked up my over the counter hardware and installed it this weekend.
Alignment is booked for Thursday and track on Friday. I'll post up a few notes on the weekend.
09-07-2010, 01:59 PM | #27 |
Rep 2,138
Drives: Me
You'll be at the track a week before me.
09-07-2010, 02:30 PM | #28 |
Bimmer Noob
30
Rep 566
Installed camber bolts and manually adjusted for max camber.
I ended up with -2.5 Left side and -3.1 Right side. After an alignment, I ended up with -2.5/-2.5. The difference in the front handling is very noticeable during autocrossing. In fact, the back end came around on me once. I am used to the understeer so was surprised when the front held. I highly recommend this mod. Cheap, quick and noticeable results!
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
09-07-2010, 03:39 PM | #29 | |
Rep 1,143
I'd like to try sourcing these from McMaster-Carr using actual shims instead of washers for much closer tolerances. |
09-07-2010, 03:50 PM | #30 | |
Rep 11,667
The washers are ~2.50mm each (3 per bolt) The OE bolts are 20mm, so with the added 2 washers it is threaded in to the same point. IMO shim stock is overkill. With manufacturing tolerances, both sides will never be equal. To fine tune the camber it will still need adjusting at the top.
09-07-2010, 05:22 PM | #31 | |
Rep 1,143
09-07-2010, 07:49 PM | #32 | |
Rep 11,667
They are 1.75mm
09-07-2010, 11:15 PM | #33 |
Rep 1,143
Thanks!
So, just to check, something like: http://www.mcmaster.com/#90854a223/=8r2a9e http://www.mcmaster.com/#91455a150/=8r2du0 ? I'll be happy to pass on the extra bits to anyone interested. |
09-08-2010, 07:36 AM | #34 |
Rep 2,138
Drives: Me
Oh, I forgot to say that the stut hole must be perfectly lined op with the threaded hole in the kingpin. If it's not, the bolt won't thread and you could cross thread it.
09-08-2010, 02:05 PM | #35 |
Rep 11,667
FWIW, when I installed mine;
1. I just loosened the upper bolt and kept it in place to maintain bolt hole alignment. 2. I removed one of the lower OE bolts and turned in one of the new longer bolts (only 2-3 turns) sans washers. 3. I then removed the other OE bolt and pried a gap big enough to slide in two camber washers. The 1st bolt (step #2) maintained hole alignment for the 2nd new bolt. 4. I removed bolt in step #2 and added washers, then re-installed. As pointed out below, be sure to use red loctite
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 09-08-2010 at 03:24 PM.. |
09-08-2010, 02:11 PM | #36 |
Bimmer Noob
30
Rep 566
Did same, but added Red Loctite to the threads of the camber bolts since the originals had it.
09-08-2010, 02:37 PM | #37 |
Rep 11,667
^ good point, I missed that in the write up.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 09-08-2010 at 03:23 PM.. |
09-08-2010, 02:49 PM | #38 |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
09-08-2010, 03:03 PM | #39 |
Rep 2,138
Drives: Me
Yes, add some Red Loctite. When I pulled my OEM bolts out, they had some on them.
09-08-2010, 03:22 PM | #40 |
Rep 11,667
LOL... I missed it on the write up; not the install.
...tough crowd [fixed]
09-08-2010, 04:42 PM | #41 | |
Rep 165
09-08-2010, 05:40 PM | #42 |
M = Midlife Crisis
65
Rep 2,006
So we should not follow your DIY posts going forward
09-08-2010, 05:43 PM | #43 |
Rep 11,667
Do as I do, not as I say.
09-08-2010, 06:43 PM | #44 |
M = Midlife Crisis
65
Rep 2,006
So everyone comes to your house to watch you work on our cars Pat cooks dinner too
