04-20-2018, 10:33 PM | #1 |
Rep 911
Adjustable sway bar links
Can't seem to find any adjustable units for the rear sway bar (3.0si), not even for the Z4M.
Front's are easy to find. Can anyone recommend a rear adjustable link?
Andre - 2J into a Z4 Coupe!
04-21-2018, 05:34 PM | #2 |
Rep 2,704
This is what I am running http://www.hotchkis.net/product/1999...rt-suspension/
I concluded that if an E46 sway bar fits our cars then so should the end links Worked as they should. http://www.zpost.com/forums/showthread.php?t=772400
04-21-2018, 09:37 PM | #3 |
Rep 911
Awesome, thanks for the links. For some reason, searching on zpost and tabbing through 5 pages, I could not find information
04-21-2018, 10:07 PM | #4 |
10846
Rep 4,892
Ground control also has a version with dual pillowball (probably more track focussed than the hotchkis ones)
https://groundcontrolstore.com/colle...djustable-pair
