11-13-2017, 03:39 PM | #1 |
Rep 264
Broken Factory Fender Strut Brace Mount Fix?
A long time ago, the factory strut brace fender mount on my '04 3.0i broke off (number 6 in the attached image, p/n 41007193040) and I am now looking to fix the mount. When it originally broke, I bought and used the ultra racing 3 point brace off of eBay as the fix. However due to a change in my local CCA autocross rules, this aftermarket brace will push the car into a higher class and I need to revert to the factory braces, or run without.
Has anyone encountered this issue before? If so, is this something a YouTube Certified shade tree mechanic like myself can fix or is this something a body shop needs to handle?
2017 M2 - Camber Hubs, MPE, and some other goodies 2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s 2004 Z4 3.0i - Gone, but not forgotten! |
11-15-2017, 03:17 AM | #3 |
10625
Rep 4,848
There's a bmw repair instruction for that.
It basically says to weld the facelift strut bar bracket in place (so welding required) Dont run the car without the braces!
jns_e8574.00 |
11-15-2017, 08:58 AM | #4 | |
Rep 264
For now the eBay brace stays on!
11-15-2017, 10:09 AM | #5 |
Rep 870
Drives: 2006 BMW Z4M Roadster
I don't have the bulletin, but I bookmarked this page some time back:
http://www.bimmerfest.com/forums/sho...d.php?t=231800 Edit: There is a link to a bulletin in the last post in the thread linked above. Hope that helps. Salty
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete Last edited by SaltyNC; 11-15-2017 at 10:19 AM.. |
jns_e8574.00 |
11-15-2017, 11:38 AM | #6 |
10625
Rep 4,848
Here you are
I think there's one page missing (page 2) but you get the point.
08-26-2018, 12:17 PM | #7 |
636
Rep 3,124
This just happened to me.
Looks like this is probably the aforementioned ultra racing 3 point brace, and I bet it won't fit over an S54.
