      09-03-2017, 06:14 PM   #1
DanFromTucson
Drives: Z4 M Coupe
Bilstein B6 for Z4M: Reuse Rear Bumpstop & Dust Cover?
I just installed some Bilstein B6 shocks in the rear of my Z4MC as part of my 55,000 mile suspension refresh. The Bilsteins didn't come with bumpstops or dust covers, so I assume I'm supposed to reuse the assembly from my old shocks.
The diagram in the box shows an external bump stop, so that seems to support my theory.
Can someone confirm?
      09-03-2017, 10:30 PM   #2
m5m3mc
Drives: M-B C63
Bilstein doesn't sell one? The bump stop actually acts as a progressive spring and not just to prevent bottoming out. I personally would never reuse one unless it was pretty much new to begin with.
      09-04-2017, 07:18 AM   #3
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
You're supposed to buy new bump stops (item 4) and new mounts (item 6) to go with your new shocks. You can reuse the dust covers if they're not damaged or haven't become embrittled with age. The Rogue Engineering mounts are a better choice than the OEM, but at a minimum you should replace the OEM.
http://bmwfans.info/parts-catalog/E8...ing_and_parts/
Top Down 365
      09-04-2017, 08:51 AM   #4
DanFromTucson
Drives: Z4 M Coupe
Thanks guys. My old bump stops look fine, but I guess I'll order some new ones when I order replacements for the clips I broke dismantling my interior.
I did install Rogue mounts, so at least I'll be able to change the bump stops easily in a week or 2!
      10-16-2017, 08:28 AM   #5
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Agreed -
Agreed - I replaced all of the above during my recent suspension upgrades:
Bilstein B12 Pro-Kit & Eibach Pro-Kit Springs Installed....
Replaced OEM front control arms with BMW ZHP performance control arms, OEM front control arm bushings, all new spring pads, strut support guides and bearings....front lowered 3/4 inch & rear 3/8 inch....4 wheel alignment....performed by Eastside Bavarian - Eric the Tech's acumen, detail, thoroughness and precision is awesome....
First impressions....the visual change is freaking awesome....the seat time reveals it feels like it's on rails....freaking awesome.
Racerbruce
      02-05-2018, 02:10 PM   #6
Dan Bilzerian
Dan Bilzerian's Avatar
355
Drives: E90 325i 6MT
You didn't happen to measure the height of the bump stops did you? I'm doing a refresh on my car and trying to get the right height bump stops to match the how much I'm lowering the car.
      02-09-2018, 09:01 PM   #7
racerbruce
racerbruce's Avatar
3854
Measure?
I did not -
Racerbruce
