      04-20-2018, 10:33 PM   #1
dre99gsx
Drives: 1994 Toyota Supra
Adjustable sway bar links
Can't seem to find any adjustable units for the rear sway bar (3.0si), not even for the Z4M.
Front's are easy to find.
Can anyone recommend a rear adjustable link?
      04-21-2018, 05:34 PM   #2
Steeler
Steeler's Avatar
2429
This is what I am running http://www.hotchkis.net/product/1999...rt-suspension/
I concluded that if an E46 sway bar fits our cars then so should the end links
Worked as they should.
http://www.zpost.com/forums/showthread.php?t=772400
      04-21-2018, 09:37 PM   #3
dre99gsx
Awesome, thanks for the links. For some reason, searching on zpost and tabbing through 5 pages, I could not find information
      04-21-2018, 10:07 PM   #4
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Drives: Z4 3.0i ESS TS2+
Ground control also has a version with dual pillowball (probably more track focussed than the hotchkis ones)
https://groundcontrolstore.com/colle...djustable-pair
