08-31-2011, 09:50 AM | #1 |
instagram 997turbotom
279
Rep 7,377
removing headlight washers?
What did people here use to block the water line running to the headlight washers?
08-31-2011, 11:22 AM | #2 |
Rep 191
I just unplugged the pump power supply.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
08-31-2011, 11:28 AM | #3 |
Rep 5,329
i just uplugged it and it pissed all over the floor, lol.....
08-31-2011, 11:39 AM | #4 |
707
So Roffle, do you want to make sure they don't turn on (pull fuse, or disconnect pump power supply), or actually remove and block the water line going to the washer nozzles themselves? I'm guessing if you disconnect the line and want to "plug" them you'd need to find some kind of plug that would fit drip system tubing or perhaps fish air line/pump tubing (hardware store or pet store perhaps).
08-31-2011, 12:18 PM | #5 |
279
Rep 7,377
I'd like to remove the lines going to the headlight nozzles, at the "T" fitting in the water line. Also remove the water lines going from that "T" to them. Just unplugging the water line means everything else drains out too (the windshielf washer system)
for 1. very minor weight savings up front 2. so I don't lose water/meth mixture on washing the unnecessaries
08-31-2011, 02:43 PM | #6 |
Bimmer Noob
30
Rep 566
I snipped the tube @ the pump and used a zip tie to close the tube. I removed the rest of the equipment.
There is an opportunity to make a cap/plug for removing the headlight pump altogether.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
08-31-2011, 04:12 PM | #7 |
Rep 2,138
Drives: Me
Just disconnected the electrical connector to the secondary pump that powers the headlight washers. No issue. No leaks. They never activate.
This is the quickest and easiest way, unless you want to remove the entire assembly. |
08-31-2011, 04:55 PM | #9 |
Rep 2,138
Drives: Me
It's the rear most one. I wish I had a picture.
Disconnect, cover the connectors and tie back. |
08-31-2011, 09:26 PM | #11 |
Rep 11,667
I did mine when I did the headlights.
check this thread for pics; the last pic shows the washer connection with a short tube & plugged end. http://www.zpost.com/forums/showthread.php?t=572878 .
