      01-31-2010, 04:33 AM   #1
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
Understeer vs Oversteer
Based on individual opinions what do you guys experience at the most on the Z4 MC with OEM setup??
What did you do to correct or adapt to your way of driving??
What was your goal?Street or Track? % if both.
      01-31-2010, 04:08 PM   #2
jragan
Imola Lover
jragan's Avatar
These cars are known for understeer. More negative camber in the front mostly addresses this.
Hers: 997-1 C4S: Pics
      02-01-2010, 01:34 AM   #3
silversprint
Drives: Z4M
Understeer factory. As noted more front camber and the car is very nuetral. You can do this by simply shimming the two bottom strut bolts to get the needed -2.5 camber.
MR-S Track -2100lbs/300hp
Miata
Z4M Coupe (Sold)
      02-19-2010, 06:27 PM   #4
Car_Girl
Car_Girl's Avatar
Drives: 2013 BMW X5 xDrive 5.0i
X2 - Same mod recommended on the iwsti site. They say it makes all the difference.
      02-20-2010, 01:40 AM   #5
Diokaef
Engineer
Diokaef's Avatar
I'm going with -2.75 front, toe .10 and -2.45 rear toe .10
      02-22-2010, 06:03 PM   #6
silversprint
Drives: Z4M
Why so much rear camber??
Miata
Z4M Coupe (Sold)
      06-02-2010, 03:48 PM   #7
Diokaef
Engineer
Diokaef's Avatar
Because of the tires having square wall.
Tags
suspension
