03-27-2014, 11:10 PM | #1 |
Rep 195
Is it ok to mount PS2's inside out?
My front tires took a beating at my last track weekend. I'd like to get at least one more track weekend out of them. I've read various opinions on whether PS2s can/should be mounted inside out to even out tread wear. Does anyone have experience with this?
Thanks |
03-29-2014, 07:41 AM | #2 |
Rep 441
Correct me if I'm wrong but ps2's are asymmetric, so you can rotate left and right
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread |
03-29-2014, 08:52 AM | #3 | |
Rep 2,176
George |
03-29-2014, 10:54 AM | #4 | |
Wagon life
39
Rep 991
03-30-2014, 12:18 AM | #5 |
Rep 195
Agreed. I should mention that when I got the car it had PS2s all around, but the rears were shot while the fronts were fresh. I didn't want to switch to PSSs on just one axle so replaced the rears with new PS2s. At the time I wasn't planning on tracking the car (very much). Well, that has changed and while I will be dialing in more neg camber before my next event the damage is done. Will 2.5 deg prevent much more outside wear on these tires?
Best option would probably be dedicated track tires since the Michelins are still healthy for street, but I'm not sure they can handle another track weekend without cording the outside shoulders, and I have to drive home on them. When I bought this car I told my wife and myself that I wouldn't collect stacks of wheels, tires, and other track paraphernalia. This was just going to be a fun weekend car that wouldn't see the track. Hmmm... I guess it's off to tirerack I go! |
03-30-2014, 01:10 AM | #6 |
707
-2.5 will help considerably, easily done with camber washers (Turner, about 20 bucks).
I do not recommend PSS for hard track work. RS-3s or Dunlop Direzza ZIIs are much more suited to the track use IMO. I ran the new Dunlops last weekend on my E36 and was quite impressed. No greasiness, up to speed quickly, very predictable and held up great! I found they ran best at 37-38 hot (I started the day at 30 cold) and adjusted through the days as it got warmer. I always liked the old Star Specs (used on my Z4M); these are better. |
03-30-2014, 01:21 AM | #7 |
Rep 195
Thanks. I've already ordered the Turner washers. I assume that was you I was talking with at Thunderhill last weekend? Thanks for the tips! I think I'll just bite the bullet and order some apex wheels for the track. No point in screwing around anymore.
03-30-2014, 11:43 AM | #8 | |
Rep 2,176
George |
03-30-2014, 12:07 PM | #9 | |
707
From what I saw last weekend tires plus alignment are the priorities now, and other considerations such as coils can come a little further on. And Yeah, that's me! (Ron) Definitely wheels and tires. Can't say enough good things about those new Dunlops.... Use two washers and get it set for street at around -1.7--1.8. 1/16th total toe-in. Mark the strut nuts. Then move them all the way inward for track days. That will get you -2.5 to -2.7 and a bit of toe-out. Tire wear will vastly improve as will front grip. (Plan on adjusting a bit since it changes the dynamics--in a good way--of the car.) Let me know when you plan to be there again. Last edited by Finnegan; 03-30-2014 at 12:12 PM.. |
03-30-2014, 06:20 PM | #11 |
Rep 68
I would not at all recommend going to an R-Compound tire unless you are already very experienced at the track. The lack of feedback compared to a street tire makes them less predictable, and R-Comps also have the added effect of covering-up bad driving with extra grip.
You're far better off getting some good time in on a tire like the Hankook RS3 or Nitto NT-05, then transitioning to an R-Compound later.
RPI scoop, Euro headers, SS PowerLoop, Epic race tune, AKG motor/trans mounts, Turner camber bolts |
03-30-2014, 06:31 PM | #12 | |
Rep 2,176
George |
