      08-05-2015, 01:18 PM   #1
Spedracer81
Drives: Z4MC
Castrol Edge oil..bottle change?
Hello, I'm going to be performing an oil change soon, is this the same oil as the castor edge 10w60 I've been using? I got it at the BMW dealership
thanks
| 2008 Interlagos Blue Z4MC |
| AA Tuning | RPI Scoop | H&R Sport Springs | Sportline CS 16 CSL Wheels | Magna Flow Custom Exhaust |
      08-05-2015, 01:20 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
BMW switched from Castrol to Shell.
Supposedly just as good. I have a batch in the garage for my next change.
      08-05-2015, 05:03 PM   #3
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
Might want to also consider liquiMoli. M3 owners have been using LM for ages with positive results. I recently switched over to it as well
The Raspinator
      08-05-2015, 08:32 PM   #4
Spedracer81
Drives: Z4MC
So..I purchased 6 qts intending to do my oil change soon, should I use this or get something else?
      08-05-2015, 08:32 PM   #5
David70
Drives: 06 Z4M Coupe - 13 Cadillac ATS
After years of people saying we needed to use Castrol because it was specially designed to work with our engines suddenly a new contract with Shell and we are supposed to move on to the new recommended product....
I have used Liqui Moly for a few years.
      08-05-2015, 09:45 PM   #6
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Unless you push your car into extreme parameters, all name brand synthetic oil will perform similarly. It's more important to stick to proper service intervals and use quality filters. Don't mix different brands of oil.
      08-05-2015, 09:46 PM   #7
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
which specific LM do you use guys?
Powered by
      08-05-2015, 11:13 PM   #8
StickMon
StickMon's Avatar
Drives: 2006 MR
Both. Like pokey said, they're all good.
Use what you have and take the time to the next change to research and see if you want to go to something else.
Search turns up Liqui Moly 10w-60 GT1.
Which looks like it comes in at least 3 different colored 5l jugs.
Collect them all?
      08-06-2015, 01:50 AM   #9
tikamak
Lebanon
58
I'm using Mobil1 ow40
      08-06-2015, 08:09 AM   #10
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
You can get Castrol Edge TWS at O'Reilly auto now.
They might have to order it, but it will be in the next day.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      08-06-2015, 08:25 AM   #11
GuidoK
#buildnotbought
GuidoK's Avatar
10866
Drives: Z4 3.0i ESS TS2+
ow40 in a hot climate as Lebanon?
      08-06-2015, 09:49 AM   #12
tikamak
Lebanon
58
Yup, it's handling the supercharged motor like a champ
      08-06-2015, 11:54 AM   #13
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Some on the M3 forums indicates that you can get Castrol Edge TWS at Audi dealers for less than $10/liter! I will confirm it on my next oil change in about 4 to 5 months
      08-06-2015, 10:40 PM   #14
dfjaws
dfjaws's Avatar
Drives: E90 M3 / E86 M Coupe
I use the new BMW Shell oil. I like it. No change in oil consumption or anything. I'd just stick with that, especially since you already have it.
      08-07-2015, 08:43 AM   #15
David70
http://www.ecstuning.com/BMW-Z4-M_Co.../Oil/ES248959/
I bought it based on reviews and some Blackstone oil tests.
Added bonus is the $9 a liter price (I don't recommend buying oil on price, just an added bonus).
If I already purchased the new BMW Shell oil I would use it.
      08-07-2015, 11:59 AM   #16
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I've used Liqui Moly for engine oil for couple of years. Blackstone have one high lead content report, but others performed better than Catrol 10w-60. I am ready to send another sample out next week.
I use Liqui Moly Gear Oil 75w-140 LS. No noise of any sort.
