View Poll Results: WPC treatment? | |||
Yes | 9 | 100.00% | |
No | 0 | 0% | |
Voters: 9. You may not vote on this poll |
11-02-2015, 08:49 PM | #23 |
I plead the 5th.
523
Rep 1,519
Given your miles, that doesn't sound too bad! Still must feel nice to have it done.
Looking forward to some pics.
-Matt
11-06-2015, 02:10 AM | #24 |
1621
Rep 4,295
Stick, glad your bearings were not too bad mate.. yeah i figured on 1000 kms and i generally drive below 4k , so no issues there mate.
I had my carrier bearing fail a few months back mate, and you'll know it when it goes man.. massive vibrations at launch, but smooths out when load drops.. (and not in every gear, pretty much only in 1rst and 2nd for me.) i had my guibo replaced at the same time, though it was still in pretty ok nick..
Powered by |
11-06-2015, 11:22 AM | #25 |
Rep 5,329
looking forward to pics.
11-06-2015, 12:35 PM | #26 |
636
Rep 3,124
Pics
To recap - 128k miles, rarely over 5000 rpm, never over 7000 rpm, at least since I bought it with 40k miles.
Cylinder 1 --> 6 Tops on top, bottoms on bottom.
11-06-2015, 02:08 PM | #27 | |
Rep 912
11-06-2015, 02:36 PM | #28 | |
Rep 11,668
Props to Andrew for doing a test! That's surprising info. It would be interesting to get some feedback from ARP.
11-06-2015, 02:39 PM | #29 |
636
Rep 3,124
Castrol 10W-60. Standard ///M stuff.
Just switched to the new "Twin Power Turbo". Something for those with ARP bolts to lose sleep over.
11-06-2015, 09:19 PM | #31 |
Rep 2,138
Drives: Me
Of course the uppers look bad.
The upper bearings have the most load, and wear first. All in all, I think his bearing look normal for the amount of mileage he has on the car and the relative ease (no slam intended) in which he had driven the car. It was just time for this maintenance and a rod bearing replacement will have to happen with every S54 at least one in its lifetime. |
11-06-2015, 11:34 PM | #33 | |
636
Rep 3,124
Yours look more consistently worn, or maybe it's just because mine are only starting to get through the lead.
11-07-2015, 01:19 AM | #34 |
1621
Rep 4,295
thanks for the close up mate, yeah, mine were def much worse.. and your spot on for having this done mate, peace of mind is worth a lot.
I agree Ship, no hassle intended, just nice to get a close up of those top shells. i guess warming up the car properly is a massive factor on these engines and I agree, should be done on every S54 around 100k. Whats next Stick?
Powered by |
11-07-2015, 10:40 PM | #35 |
636
Rep 3,124
BimmerWorld spherical RTABs.
Sway bar end links and bushings at both ends. Maybe stock, maybe not.
02-26-2016, 11:34 PM | #37 |
Rep 2,869
Wow...that looks fantastic - those WPC stuffs actually works
02-27-2016, 08:11 AM | #38 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Congrats on that positive report.
Salty
03-07-2016, 08:21 AM | #39 |
Rep 503
Drives: Z4 M Coupe
Just saw this thread and briefly read through it...
Mine did out of the blue two and a half years ago. Well maintained, occasionally tracked, semi-frequent use of 7000+ RPM, 65,000 miles... It scored 2 connecting rods and the crankshaft. Costed a lot of money to get it fixed here....
