07-31-2022, 06:08 AM | #1 |
Rep 783
Looking for a 3.90 to 4.10 diff.
The stock M differential ratio is 3.64:1 and I'm thinking about changing to a 3.90 or 4.10 but I really have no idea where to start.
Is there a vendor that sells different ring and pinion gears for these diffs or would I be looking for the entire diff from another car? Thanks, Chris
2008 E86 M coupe
07-31-2022, 06:27 AM | #2 |
Rep 399
Take a look here -
https://www.ecstuning.com/BMW-Z4-M_C...nd_Pinion_Set/
Powered by
grannyknot953.00 |
07-31-2022, 06:30 AM | #3 |
Get off my lawn
938
Rep 1,162
The ring and pinion set in both ratios are still manufactured by BMW, available at a number of retailers.
https://www.bimmerworld.com/Drivelin...kaAtHAEALw_wcB The direction you go depends on your driving preferences and any potential for forced induction in the future. |
grannyknot953.00 |
07-31-2022, 10:40 AM | #4 |
Rep 267
Drives: 2006 Z4 M Roadster
Why are you thinking of making the change? Higher trap speeds? Lower cruising RPMs? Plans to track the car? Just curious.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
07-31-2022, 11:13 AM | #5 |
Rep 977
My 4.10 gear set have been collecting dust for more than a year, need to make time for the install.
I got mine from diffsonline. But as said above, ECS, Bimmerworld and a few others sell them. |
grannyknot953.00 |
07-31-2022, 02:38 PM | #6 | |||
Rep 783
Thanks, diffsonline looks like a one stop shop.
2008 E86 M coupe
07-31-2022, 03:11 PM | #7 |
Rep 977
Ring and pinion gears are shared across e46, e85/6, e60 and e92 ///M cars.
grannyknot953.00 |
07-31-2022, 04:05 PM | #8 | |
Rep 783
So many vendors that sell e46 M3 parts don't have much experience with Z4's, hard to get a clear answer out of them.
2008 E86 M coupe
08-01-2022, 07:22 AM | #9 |
Rep 399
grannyknot
BTW you have great opportunity to try locally 4.10 with supercharger , It feels great |
grannyknot953.00 |
08-01-2022, 11:03 AM | #10 | |
Rep 783
Are you documenting your supercharger install in a thread somewhere? I have had that "Chasing more power" sickness before, actually all of my driving life. It's like a gambling addiction, but this time around with this car I'm trying to keep things a bit more basic than the cars I've built in the past. Bimmerworld seems to have the best deal around for the 3.91 set I want and Diffsonline has a ready to go overhaul kits with everything needed, https://diffsonline.com/differential.../rebuild-kits/
2008 E86 M coupe
08-01-2022, 11:42 AM | #11 | |
Rep 399
Yes it is me I may go up north tonight if no rain, we can meet somewhere in Vlad's area
Powered by
08-04-2022, 08:01 AM | #12 |
1624
Rep 4,296
Bear in mind, as maupineda said, the crown and pin are shared across models, the diff however is different from the E46 M3,if your looking to refresh while your in there...
08-04-2022, 03:06 PM | #13 | |
Rep 783
They having a summer sale on right now so I ordered the whole bearing set with seals , the free play shim, all new clutch pack for 481.00 Euros and that includes shipping, I couldn't pass that up. I wasn't intending on doing an entire rebuild but hell, I'm in there anyway, might as well do it right.
2008 E86 M coupe
08-06-2022, 04:00 AM | #14 |
1624
Rep 4,296
thats great, the race pumpkin in the diff in my car is from them, what did you go for?
edit: ***shit!!!!*** i just saw that pic, you didnt buy the whole pumpkin? but friction plates and and bearings? just a heads up, the number of friction plates in the z4m diff differs from the e46m3.. (there are more), MORE IMPORTANTLY!!!, its nearly impossible to open the pumkin. youll need to make a key.. (gets expensive) and then get about 5 huge blokes on a massive end and see if you can turn it off. Youll also need to drill out the locking ball. ive got some pics somewhere, but i think they are also shared on here somewhere if you do a search.. Have they shipped it yet? if not, you might be better/cheaper off just buying a new pumkin from them, and you can specify what ramps youll like. this is what i ended up doing after finally getting the fucking thing to open.. yeah i said fucking, its a absolute nightmare...
Powered by Last edited by Vanne; 08-06-2022 at 04:10 AM.. |
08-06-2022, 06:44 AM | #15 |
Rep 783
Hmmmm, They have already shipped the parts, well I enjoy a challenge
If I get in trouble I have a local transmission/diff shop near me that checks over my work for me, but if you come across those photos I would really appreciate it, I'll also start searching here on the fourm. Thanks Vane
2008 E86 M coupe
08-06-2022, 01:57 PM | #16 |
Rep 783
maupineda , Vanne , I found that thread with all the info and pics of the M3 and Z4M diffs, https://www.zpost.com/forums/showthread.php?t=393888
Good info, I wish I had seen that tool that RacingDiffs sells before they shipped, funny he didn't mention it. Although looking at the image of the tool he offers it doesn't look like it would handle a 4 metre extension needed to remove the top of the LSD unit. I'll have a go at making one first before I try anything else. Also, here is RacingDiffs video on the Z4M diff,
2008 E86 M coupe
08-06-2022, 03:54 PM | #17 |
Rep 977
I bought that kit too, as well as the tool, but I have chosen not to bother, I have read that all replacement clutches just don't last as long as the OE, and I have no issue with my diff. so when I do the gear swap, I would leave the diff alone and save the kit for later. My car is 80k km so I don't see the need to bother with the diff at this point.
08-06-2022, 04:07 PM | #18 | |
Rep 783
2008 E86 M coupe
08-09-2022, 04:29 AM | #20 |
Rep 783
It all arrived yesterday so that's 7 days from Serbia to my door, pretty good.
Everything looks to be top quality, he even has his own seals made up, they feel a little more substantial than the BMW or Victor-Reins seals.
2008 E86 M coupe
08-09-2022, 05:09 AM | #21 |
Rep 977
Is the large pinion bearing there a ball bearing? If so, you receive the E92 kit, which is identical to the E46 v2 and Z4M except for that item, ours is a taper roller bearing. That is not compatible with our pumpkin
