      04-15-2021, 10:35 PM   #1
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
Swaybar Weight
For those interested, before selling off my Turner Swaybar kit, thought I
would check out t the weight differences between stock, Turner and
Hotchkis front bars.
Both the Hotchkis and Turner bars are spec’d as E46 M3 Specific but fit the Z4m without issue.
Stock front 14 lbs
Turner 30.4 mm 18 lbs
Hotchkis 30.6 mm 8lbs
Turner Rear 25 mm 10lbs
The Stock Rear Bar is on my car and never ordered the Hotchkis Rear, so
couldn’t weigh this pieces
Note: Hotchkis bar is Hallow, hence the weight savings. Let’s see how stiff it
is once track season starts.
AriuSen776.50
      09-14-2021, 05:42 PM   #2
ctdriver86
Drives: e46 m3
What's the verdict on the hotchkiss bar?
      09-14-2021, 09:27 PM   #3
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
To be honest, can’t tell the difference between the Hotchkis and Turner bars.
Ran them both in the stiffest setting.
      09-15-2021, 07:54 AM   #4
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
I thought the weight was significant on the H&R when I got the box! Should have had you weight them before I installed! Hollow would have been the way to go I guess.
From what I've read for the Z4 and E46 chassis, full stiff front, full soft rear and I've been happy with that for now. Have you tried soft in the rear?
TC Kline racing actually recommends stock rear bar.
      09-15-2021, 10:04 AM   #5
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
When I had the Turner set up i did run the rear bar full soft and front either
Med or Hard. It worked well with a staggered tire set up.
Once I went to Square set up, it was simply too much.
I tried 5 - 6 different spring combos and found the rear end would on occation
do a snap oversteer at the limit. Once I went to the stock bar this became a
whole lot more controlable.
3GFX722.50
