      04-06-2019, 03:33 PM   #1
lawms98
Nathan
Drives: 2003 BMW Z4 E85
Exclamation Tapping/Click on Startup
Hi people,
I was wondering if anyone has experienced the same issue as me.
Firstly, this issue happens very randomly. its does not happen 10/10 times I start my car. it happens maybe about 3/10 times.
It mostly happens when my car has been sat for a while or overnight. When I start my car up, it starts making a tap/click/tick sound for around 10-15 seconds and it completely disappears.
what can it possibly be? Vanos? Lifters? Injectors?
      04-06-2019, 04:09 PM   #2
wdb
dances with roads
wdb's Avatar
4732
If it's an N52 it could be the hydraulic lifters. There was a recall for it I believe. I'm not 100% certain but I think they tended to bleed down if they sat for a while, and you'd get a tapping sound for a few seconds on startup until they pumped up again.
      04-07-2019, 01:55 AM   #3
KevinC
your average JAMF
KevinC's Avatar
Not an N52 based on his info under his username.
'21 M2 Comp
'19 Golf R
      04-09-2019, 10:12 PM   #4
lawms98
Nathan
I have the m54b25 engine
      04-10-2019, 09:38 AM   #5
The HACK
The HACK's Avatar
1821
What oil is in the engine?
      04-10-2019, 02:35 PM   #6
ShakyDog
ShakyDog's Avatar
Drives: 2007 Z4 3.0i Alpine White/Red
Is the sound coming from the sound system? When my audio cable is connected with nothing on the other end it makes a sound like somone tapping on a live microphone. Is that the sound?
Steve
      04-10-2019, 11:59 PM   #7
lawms98
Nathan
honestly I have no clue. I bought this car barely a month ago and im planning on doing the oil change myself soon.
      04-11-2019, 12:00 AM   #8
lawms98
Nathan
I am sure its from the engine. the tapping rate is synced with the revs as well. when I rev the engine, the tapping gets quicker
      04-16-2019, 09:20 AM   #9
The HACK
The HACK's Avatar
1821
There could be a thousand different causes, almost all of which can’t be resolved by description alone.
Here are a few higher possibility causes.
Low oil.
Improper weight oil.
VANOS pump.
If you don’t want to chase wild goose, I’d start with changing the oil now to a BMW LL01 approved, 0W-30 or 5W-30 weight synthetic and see if it gets better or eliminate the problem entirely. If not, take it to a local mechanic (your location suggest you’re no more than a 15 minute drive from a few really good BMW Indies), see if he can reproduce it and locate the sound with a boroscope.
      04-16-2019, 11:34 AM   #10
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
As The Hack said get that oil outa there. I have that motor in my E46 330i and its quieter and smoother than S54! Maybe some sludge in the valvetrain? How many miles on motor?
      04-16-2019, 08:24 PM   #11
lawms98
Nathan
@garz747 motor has 117k miles.
@the hack do you think its gonna be an expensive fix. Does it sound like a serious issue to you?
Thanks
      04-17-2019, 02:10 PM   #12
MinneapolisJeff
Drives: 2003 BMW Z4 3.0i
Do you park on a hill? I had a ticking sound when the vehicle was left for a few days on a hill and the conclusion I came to was oil drained out the engine and it took some minutes to get it pumped back once I started the car.
the stable:
2003 BMW Z4 3.0i
2020 Mitsubishi Outlander SE
2021 Jeep Gladiator Rubicon
      04-25-2019, 08:34 PM   #13
lawms98
Nathan
No I park on a level surface.
      04-26-2019, 10:32 AM   #14
The HACK
The HACK's Avatar
1821
If I can tell you sight unseen based on your description, I wouldn’t be here posting. I’d be on a private island sipping pina coladas surrounded by hot 20 year olds frolicking nakedly through the crystal clear water.
Because I would have the power of foresight and be able to guess the winning number of each Lotto draw.
Take it to a local, trustworthy mechanic if you want a real resolution on the issue, rather than listen to teh interweb speculation is probably the best advice I can give you.
No matter how smart some of us sound, we’re just a bunch of unqualified keyboard monkeys.
Tags
noise, start, tap, tick
