      02-15-2021, 08:58 AM   #1
noblex
Drives: BMW Z4 E89 20i
Weird grating/metallic noise from front end
Good morning everyone.
I have a 2014 BMW Z4 E89 that, after having the headcover replaced (and tappet gasket while I was at it) started making this worrisome croaking/metallic noise.
The noise is coming from the front end, but can't figure out the exact spot (could be the RIGHT wheel, could be the engine, could be the dome bars, etc).
I've noticed it happens more when I'm on an uneven road, or going over a bump, or turning left.
Example:
Another example (less grating, more metallic):
Does this give you any ideas?
      02-15-2021, 09:35 PM   #2
jwolf
Drives: 135i M-Sport MT N-55 / Z4 3.0i
Does it make the noise sitting still, not rolling? = engine
Does it make noise coasting with the motor off? = suspension (turn key back on to prevent steering lock)
Good luck! I had a really nasty creak that ended up being the tower struts running from the firewall to the shock towers. e85
      02-17-2021, 02:13 AM   #3
noblex
Hi!
Thanks for the advice.
It seems it makes the noise only while moving. Standing still (engine on or off) doesn't make any noise.
      02-17-2021, 09:40 AM   #4
mmm-five
mmm-five's Avatar
Drives: 2006 Z4MC + 2015 320D M-Sport
Could it be a rotten brake disc backing plate?
      02-17-2021, 11:01 PM   #5
jwolf
Something sounds loose in the suspension maybe. Not sure I would want to drive it until a shop wiggled all the suspension bits to make sure a wheel is not about to fly off.
      02-18-2021, 09:08 PM   #6
Cyclops
Cyclops's Avatar
Drives: 09 E91 328i & 07 E86 M
To me it sounds like something rubbing on the blower fan. Was your fan turned off, if not turn it off and see if it makes noise while driving.
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning ////////////2009 328xi M-Tech E91 manual 6spd
- Instagram ->@e91kiter
Tags
e89, issue, noise
