09-14-2011, 09:58 PM | #1 |
Rep 919
Drives: BMWs
Garage List 2008 E60 M5 6MT [0.00]
2019 G01 X3 sDrive30i [0.00] 2007 E86 M Coupe [0.00] 1997 E36 M3 [10.00] 2006 E53 X5 4.8is ( ... [0.00] 2006 E85 M Roadster ... [0.00] 2002 DINAN 5 (sold) [0.00] 2013 E89 Z4 sDrive3 ... [7.00] 2011 E92 M3 (sold) [0.00] 2001 E46 M3 (sold) [0.00] 2007 R56 Cooper S ( ... [0.00] 2002 996TT (sold) [10.00] 2009 E82 135i (sold) [9.00] 2006 E85 Z4 M (sold) [6.00] 2007 B7 A4 2.0T (re ... [0.00] 2003 E46 M3 (sold) [0.00] 2002 E46 325Ci (sold) [0.00] |
Widest rear wheel for M Roadster??
Does anyone know what the widest wheel the E85 M Roadsters can handle at the rear? Or, will this fitment work?
19x10.5 ET25 My car is lowered on H&R coilovers. Also, if it DOES work size tire would you recommend 265 or 275? I don't want to have run into rubbing issues or fender modifications. THANKS |
09-15-2011, 06:55 AM | #2 |
Rep 615
Drives: 08 SG/IR Z4MR | 07 AW/Blk Z4MC
19 30 275 is what id go with. Check pics of my car, roughly -2.7 degrees of camber in the rear.
08 Z4MR | Space gray on Imola red, carbon trim
BC racing coilovers | Titan TS7 07 Z4MC | Alpine white on black, aluminum trim KWV3 | CCW LM20 | Eventuri | Rogue Engineering short shifter, mounts and exhaust | BMW Motorsports shift knob | mudflaps | stubby antennas |
09-15-2011, 07:35 PM | #4 |
///M-fanatic
193
Rep 3,885
Yeah you could probably go wider than 10.5" in the back, but you'll only be able to fit 275s, or 285s AT MOST (unless you do some hardcore fender flaring, or something to that extent etc.)
With only a slight drop from stock, I could only fit 275s in the back without rubbing. And that's with the rear fenders rolled I might add. |
09-15-2011, 07:37 PM | #5 |
Rep 919
Drives: BMWs
So...
Having coilovers dropped 1.5" all around, 10.5 wrapped in 275 will guarantee me rubbing? |
09-16-2011, 12:20 AM | #7 | |
///M-fanatic
193
Rep 3,885
Though I do suggest a fender roll regardless. |
09-16-2011, 12:35 AM | #8 |
Rep 919
Drives: BMWs
09-16-2011, 12:39 AM | #9 |
///M-fanatic
193
Rep 3,885
Yeah, the 10.5" (one inch extra width), at 20's offsets are a different story. You have to trust me on this one.
Especially with coilovers, lowered, and 275s. It's safer if you get your rear fenders rolled (at least slightly). And run some negative camber in the rear. AND get tires that aren't too bulky. I'm using Nitto NT05's for example. 275/30/19. The only time it ever rubs the fender liner (black plastic inner wheel arch piece), is @ Laguna Seca turn 6. It's a mid-speed left-hander, with a dip right at the apex. So it rubs on the passenger side just ever so slightly. |
09-16-2011, 12:41 AM | #10 | |
Rep 919
Drives: BMWs
Thanks
09-16-2011, 05:46 AM | #11 |
#dubspec
6337
Rep 5,201
09-27-2011, 12:49 PM | #13 |
///M-fanatic
193
Rep 3,885
I think 19x9 +20 fronts have already been shown to work up front, with up to 265-width tire (depending on tire brand and/or model).
However, I'm willing to bet my car on the fact that 11" rear will NOT clear. My 10.5" +22 rear is technically already sticking out the fender by a tiny bit. And I can't fit anything wider than 275s in the back without rubbing. And that's with rolled fenders and -2.2* camber in the rear, and Nitto NT05 tires sized 275/30/19. |
09-27-2011, 06:06 PM | #15 |
Rep 784
Drives: 2011.5 E90 M3
These cars already have a wide aggressive stance, you don't need to blow it out of proportions with 11 inch rears.
Just sayin' |
09-28-2011, 12:56 AM | #16 | |
Rep 881
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
my current setup is 18x9 et12 with 235/35/18 front and 18x10 et15 with 275/35/18 rear. my rear fender is shaved and im running about -3.5 camber front with maxed out caster and -2 rear. will be swapping to 255/35/18 front and 285/35/18 rear soon. spacers will have to come off oh and with that 11" rear you will actually have 30mm less inside clearance and 4mm MORE outside clearance than my current setup. hope all that info helps
09-28-2011, 01:29 PM | #18 |
Rep 881
not sure, i had a 20x10.5 et26 in the rear at one point and it was fine. but thats 12mm more inside clearance and same outside clearance as a 19x11 et32. probably gonna have to do a stretch and poke with the 11" wheels
