11-17-2016, 04:43 PM | #1 |
Rep 4
Couple of questions
Hi,
I am thinking of getting a z4 m. my first question is how many miles on a z4 before it becomes problematic, i see a lot of z4m's with 70-90k miles and i am a bit nervous about buying a performance car with that many miles. Second question is coupe or convertible? I plan to use it as a daily driver and maybe do autocross or track day very occasionally. I have just started getting into the z4 m and I hope to own one after I learn a bit more about them. Thanks guys |
11-17-2016, 06:00 PM | #2 |
636
Rep 3,124
I have nearly 150k miles on mine. Leaks oil like mad, but runs great.
Buying a high mileage one will depend on what maintenance was done by the previous owner. Do a search in these forums for Vanos to get an education on some of the more expensive things you'll want to make sure have been done. As for coupe or roadster, it depends on what the weather's like in n/a. I love having the roadster here in SoCal. Chilly today, though. Only 75°.
11-17-2016, 06:26 PM | #3 | |
Rep 2,866
Chilly day indeed - I had to break out the jacket even in my coupe Don't forget about the other expensive item - rod bearings |
11-17-2016, 07:16 PM | #4 | |
Rep 4
11-17-2016, 08:15 PM | #5 |
Rep 2,866
You know that we're just busting your chops about being chilly in SoCal 75* weather, right? The heater works fine in these cars, but my suggestion is to look for one with heated seats if you want a convertible
RedOctober32.50 deemo3191751.00 |
11-17-2016, 09:52 PM | #6 |
Rep 4
Thought so but i just wanted to be sure. I know convertibles can leak heat out really fast so i was just curious if the same issue happens in the z4
11-18-2016, 06:43 AM | #7 |
Rep 4,057
I saw one review a while back compare the Z4 heater to a small nuclear reactor approaching meltdown - you should not be cold. If the heated seats in the Z4 are anything like the ones in my wife's 328, you may find that you have to turn them down - they are that good.
Huz-Z
11-18-2016, 09:09 AM | #8 | |
KPop
148
Rep 235
Overall, I feel the Z4M's are pretty durable and the engines, aside from a few hit-or-miss issues (rod bearings on early model years, VANOS, engine mounts) are especially durable and overbuilt. My Z4M only has 35k miles, but I've had zero issues. The coupe is better suited for track and autocross thanks to a stiffer frame and body. It's actually a little heavier than the roadster, but it's hardly noticeable. I've never tracked or raced my roadster, but I'm sure it would still be a lot of fun on a track. |
11-18-2016, 09:35 AM | #9 | |
Rep 130
Serious about track days more than once in the car's life? As mentioned already, coupe is the way to go. Significantly stiffer. There are some exceptional finds around with a little bit of investigative work. Ultimately, it's whatever lights your burner, rag tops or coupes. I like the coupe, personally. I don't care about track days. |
11-18-2016, 06:43 PM | #10 | ||
Rep 4
11-20-2016, 08:45 PM | #11 |
Rep 1,910
Prototype,
Just a couple of other thoughts: First, many track-day organizations won't allow roadsters, even if they have built-in roll bars like the Z4. Second, the roadster's top holds heat just fine in my experience. The heater is great, and I defy anyone to leave the heated seats on the three-bar setting for more than a few minutes. One bar only is usually plenty! Finally, there is no question but that the Z4M is a monster sports car. At the same time, the 3.0i and 3.0si are great cars, too. Unless you really want the hyperspeed capability of the M, you might take a look at the other models, too. Happy researching and shopping! Rick F. |
11-20-2016, 09:17 PM | #12 | |
Rep 758
Top Down 365
