03-11-2016, 03:31 PM | #23 | |
Rep 725
03-11-2016, 03:35 PM | #24 |
Rep 269
It was a joke referring to the perceived randomness of the solution relating to the problem. BMW's solution to fixing range is to use a different shaped mirror (technical reasons being likely a better antenna). The joke was a reference that if I don't like how I look, I do the same thing, and buy a new mirror ("fun house style").
Nevermind, its not funny anymore, you killed the moment. |
03-12-2016, 12:19 AM | #25 |
636
Rep 3,124
You're just not using it correctly.
You have to hold it under your chin with the key pointing up touching the bottom of your chin. As seen on Top Gear. Here's another fairly recent thread on it.
03-12-2016, 06:50 AM | #26 | |
Rep 11,667
Yes, the mirror thing relates to antenna design. There are some old discussions on the topic. Funny thing is that it's not consistent as relates to the mirror. Mine works from 20' or more without resorting to the chin technique.
03-12-2016, 12:01 PM | #27 |
Rep 2,866
The mirror fix is just a band-aid, IMHO. I have the oblong mirror and the range is still horrible.
03-12-2016, 05:05 PM | #28 | |
Rep 725
I usually find if its the type of joke you have to explain it killed itself. |
03-13-2016, 07:53 AM | #30 |
Rep 870
Drives: 2006 BMW Z4M Roadster
ncnmra
We can't diagnose your range problem without pics. Please take a selfie of you holding a key under your chin. A double chin and lumpy body parts cause problems with wave propagation via the Huygens-Fresnel principle. Salty
03-13-2016, 09:15 AM | #31 | |
Rep 11,667
^ .....nicely played
03-14-2016, 04:09 PM | #34 | |
Rep 269
Still, I think with the randomness of the BMW design, we should refer to the Heisenberg Principle instead...due to the uncertainly of the effort |
03-14-2016, 04:19 PM | #35 |
636
Rep 3,124
My car's powered by an Infinite Improbability Drive.
After all of the work I've done on it, it still runs, which approaches infinitely improbable.
03-15-2016, 10:54 AM | #36 |
Rep 779
im thinking of sending mine in.. its annoying that I have to be 2-3 ft or closer and since its likely not the battery or mirror... this is probably the way to go
-Roranji
03-15-2016, 07:19 PM | #37 | |
Rep 870
Salty
11-13-2016, 11:43 AM | #39 |
Rep 53
Use the Chin Method
Sending the key to be rebuilt is unlikely to fix the range. When my CPO M Coupe was under warranty, I took it to two dealers complaining about the key range, the professional opinion from both service departments was ""yeah, it kinda sucks on these cars." Sure glad I did not buy the car new for $62,000 and get this.
Chin method (I guess temple would work too--theory is using your skull as an antenna for the key--maybe I will try dead center on the top of my head) improves range. I heard on Car Talk a guy with an Audi with the same solution. |
11-14-2016, 09:10 AM | #40 |
Rep 1,247
The head thing works - as stupid as it sounds.....and as stupid as you feel doing it. On my car it at least triples the range in open areas. I can see my car from my office window, but it will never work unless I hold it to my head when I'm in there.
I use my temple as it is easier to seem like you are scratching your head instead of using a jedi mind trick to improve the crappy range of your car's fob.
11-14-2016, 10:40 AM | #41 |
Rep 4,057
Using one's own head to amplify electromagnetic radiation go to be good for ya!
Huz-Z
11-14-2016, 02:50 PM | #42 |
Rep 1,247
I have to guess it is .000000000000000000000000000000001 % of what cell phones do to us!
11-14-2016, 03:42 PM | #43 |
Rep 4,057
11-15-2016, 04:25 AM | #44 |
1621
Rep 4,294
Can you imagine all those wifi signals in the air and what thats doing to your head.. in my job I pass through security scanners all the time, every chance I get I get them to pat me down.
