      11-16-2016, 01:39 PM   #23
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
Interested in hearing how it goes.
Already had it done on 2 S54s so I won't be the first. But there is a great improvement. I should have done a video or a set of pictures before. I will just do it in the spring when I send mine out.
EDIT: found a picture.
E86 ///M Coupe - Imola Red/Imola Red
E60 ///M5 - (6 Speed) Silverstone Metallic/Black
F06 640iX - Tanzanite Blue/Amaro Brown
K66 ///M1000RR - Competition
inTgr8r2425.50
      11-16-2016, 01:42 PM   #24
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Originally Posted by yousefnjr View Post
FWIW, my car was a bit under 70k miles when I installed the Beisan disk, and there was hardly any play at all. I think you actually do want a very small amount of play, because if it's totally slip-fit you might have a hard time installing it. 3k rpm vanos rattle completely gone btw
Agreed. You would want to leave some room for material expansion/contraction between hub and disc.
I've also noticed the disappearing of the infamous "3k rpm vanos rattle" as well after the Beisan disc installation. Although, I also did the other Beisan stuffs (rattle and seals kits) at the same time.
      11-16-2016, 01:46 PM   #25
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
Appreciated, and I don't mean to knock Beisan at all, but there is a bit of variance with the thickness of the exhaust
hub tabs, some may be more worn than others, without Beisan actually having the exhaust hub I am sure that they just drill the disks all the same diameter, so some will have more play than others.
      11-20-2016, 11:01 AM   #26
pal
pal's Avatar
433
Drives: Z4 M Coupe
The RRT tabs don't look welded on. They created a machined piece that bolts to the factory hub base. If they were welding, it would have been easier and cheaper to go the TT route. I'll double check with them on Monday.
They do have them on a few track M3's for a while now.
      12-13-2016, 04:06 PM   #27
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Does not look welded on from that picture. I too went the besian disc and multitude of other refresh offerings for the s54 by them and I must report that things are now quiet as heck. Needs a few more miles on it to loosen everything up.
Sadly I did not make the 60 day return/refund service.
Powered by
      12-13-2016, 04:36 PM   #28
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Try giving them a call anyway, I was over too and they still took mine
