10-15-2013, 06:38 PM | #1 |
Rep 395
E86 seat removal
Been searching the DIY sections for a guide on how to remove the seats in my E86 coupe (seats are sport, heated + electric) but no luck.
Can someone please help me find a guide (if it exists). In particular the seat belt guides, how do they come off? |
10-15-2013, 06:46 PM | #2 |
Rep 429
I used this:
http://www.z4-forum.com/forum/viewtopic.php?f=12&t=4474 To actually get the seats out, you'll have to rotate them before removing them, and be very careful |
10-15-2013, 09:58 PM | #3 |
1621
Rep 4,294
I couldn't get the bolt out that ties the actual belt to the base, but got the seats out far enough to restrap the bottoms with seatbelt webbing.
Just one thing, make sure you disco the battery before you start playing around there.
Powered by |
10-16-2013, 03:06 AM | #4 | |
Rep 395
That should be the only difference though. TIS isn't being very useful. |
10-16-2013, 09:57 AM | #5 |
Rep 1,034
The seatbelt guides? Those are different on the M Sport seats which you can find in all flavors of Z4. Or are you talking about something else?
10-16-2013, 10:21 AM | #6 | |
Rep 12,565
1) move the seat forward, undo the bolts on the rail in back 2) move seats for backwards, undo the bolts on the seat in the front 3) disconnect battery 4) remove the seat, unclip all the harnesses on the bottom (electric power, heat, airbag, etc). 5) undo the bolt that attaches the seatbelt on the bottom. on top, just undo the plastic seat belt clip, it just snaps in/out. if you're referring to removng the seat belt totally, that i'm not sure since i decided to keep my factory 3 point. |
10-16-2013, 12:56 PM | #9 |
Rep 12,565
If you're referring to the guide attached to the seat, I'm pretty sure you just unclip it with your hand, it just snaps on/off.
04-21-2014, 04:33 PM | #11 |
"The Midas Touch"
519
Rep 1,055
Drives: F87 LBB ///M2
Can someone confirm how the seatbelt guide comes off? Dont want to break anything
04-22-2014, 11:48 AM | #12 |
"The Midas Touch"
519
Rep 1,055
Did this last night. The top the guide snaps away from the seat then you can remove the seatbelt.
