      08-22-2011, 10:44 PM   #1
mkivbora
rubba duck squr
mkivbora's Avatar
Drives: Z4
Post your pictures!!
Post up pictures of aftermarket stereo install on z4! I\'m looking to get something other than oem. Am looking to see who\'s got what?!
Innovative performance
      08-24-2011, 01:25 PM   #2
2286
Why do you use \ before each apostrophe?
      09-12-2011, 08:27 AM   #3
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
I'm disappointed that no one has really replied to this thread. I'd like to see what people have in their cars. I guess I'll be sticking to the Dice II Mediabridge and go the safe route. People may be having a difficult time finding installers who can install a head unit properly and make it work with the existing amplifier and speaker.
      09-21-2011, 01:36 PM   #4
strokeZ
strokeZ's Avatar
Drives: '11 e92 M3 6MT
Plus Alpine 500W amp and twin 10" JL Audio subs in trunk (I have no pics for that).
      09-21-2011, 06:31 PM   #5
HaiDef
Drives: M240i
Wow, two 10's?? I have one 10W3v2 and i think it thumps way too hard
      09-22-2011, 11:04 AM   #6
strokeZ
strokeZ's Avatar
That is b/c you have a coupe. I have a roadster - the trunk is pretty much isolated with the top down and at 80 mph you need lots of thump to get the sound into the cabin. I have a single 10" in my SUV w/ half the power and its way more than enough.
      09-28-2011, 07:13 PM   #7
mkivbora
rubba duck squr
mkivbora's Avatar
Drives: Z4
looks good! Sad that this is the only picture posted though.
      09-28-2011, 09:00 PM   #8
bol
Drives: 07 M Coupe
there are some pics in my thread - http://www.zpost.com/forums/showthread.php?t=476440
      11-24-2012, 07:33 AM   #9
RecycledTeen
RecycledTeen's Avatar
Drives: Looking for E85
In for more pics...
/thread resurrection
      01-20-2013, 09:01 PM   #10
zzzzz
Drives: Z4
I need that dash kit
Nowhere to be found
      01-28-2013, 11:43 AM   #11
spr_bimmer
Drives: 2004 Z4 Roadster
during the install... all new wiring, amp speakers and head unit.
head unit.
3.5" speaker and 6" sub in stock locations.
      01-29-2013, 12:51 AM   #12
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
what kind of 6" subs are those exactly??
SOLD: 2008 M Coupe
      01-31-2013, 09:33 AM   #13
spr_bimmer
here is what i have in another thread... the subs are JL 6w3v3
Originally Posted by spr_bimmer View Post
I re did everything in mine... the previous owner did a horrible job on the sound system.
here is the previous owners wiring...
Most of my system is by Alpine, a brand i have trusted for a long time.
Added the Bluetooth and the little red box is to adapt the steering wheel controls.
The head unit is really made for ipod, i had the original in my old car and loved it. The mids are 4" (100cm).
Not pictured is the PDX-F4 amp that i'm using to power the 6.5" components and the JL 6w3v3 Subs, the 4 mids are powered by the deck.
Almost every panel in the car taken off, just shy of 17 hours of my time to install, paid a shop to do the steering wheel controls, front kick panel speakes
with tweeters located in stock locations and to wire up the bluetooth, 3 hours. Almost a full 100 feet of wire went into this install to get to all the speakers...
Started raining so i had to improvise, i should have done this at my condo in the underground parking instead.
Note the awesome random license plate i happened to get when i registered the car!
The original owner cut the factory harness so i had to solder in the new one in the dash, kind of a pain.
head unit lights up blue or red. kind of matches the interior lighting.
for the 4" speakers in the back, these alpines fit great, two top screws in the factory holes and the two bottom tabs drilled into the cars metal with self taping screws.
The door speakers i used two original mouting holes then cut up a full bracket that came with the speaker to make a little holder for the third location.
Seen on the left and cut the 2 tabs from the speaker. They are all sealed with 2 way foam tape.
The original speaker grills will need a bit of tweaking for bothe the front and rears... i will be bumping them out since the tweeters touch the grills if installed rightr now.
The subs were mounted on the factory metal plates, 3 of the 8 screws and bolts for this sub could not be installed because of clearance.
Always use proper connectors!
I'm very pleased with the result. parts and the 3 hours labour came to less than $2000 CND.
i copied this from another forum i post in... this is my car...
      01-31-2013, 09:57 AM   #14
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Nice! I might look into just grabbing those subs and an amp and running them in my stock HiFi
SOLD: 2008 M Coupe
      01-31-2013, 01:17 PM   #15
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
So to break it down:
- Tweets in the sail panels on the doors
- Coax in door panels
- Coax in the kick panels
- Coax behind each seat
- Subs in the stock locations
Is that right?
      05-14-2013, 02:15 PM   #16
norcal_cyclist
Drives: 2006 Z4 3.0si
1999 BMW 323i  [0.00]
I'm torn about the removal of the OEM headunit. At least the Z4 dash it doesn't look like it's too out of place.
      06-23-2013, 03:13 PM   #17
StayFNCY
Drives: 2002 M3
head unit.
you used the stock amp for the subs? I thought those needed about 150 rms of power... always wanted the 6.5 inch jl's thought they were so adorable LOL. but you ran stock amp just fine?
      06-24-2013, 10:58 AM   #18
spr_bimmer
no stock amp...
im pretty happy with this system!
      06-24-2013, 11:08 PM   #19
StayFNCY
Drives: 2002 M3
no stock amp...
I bet! it looks like an amazing setup. I'm still not sure if I want to go in the aftermarket stereo direction. I need to see more pics of them
      06-25-2013, 10:09 AM   #20
spr_bimmer
i had no choice, bought it off someone who did an awful job on their after market install...
this deck is direct ipod connect but my ipod died so i might put a new deck in that does bluetooth audio from my iphone5... maybe do a dual din.
