      07-03-2007, 04:36 AM   #1
Ale_72
Switzerland
Drives: BMW Z4 3.0i
Question BMW Z4 - EPS Steering issue
As many other owners, I'm experiencing the usual issue on the EPS related to high temperatures (>35° degrees).
The steering is not smooth.
I knew that BMW raised an unofficial bulletin that should address this issue.
The bulletin can be found on the BMW TIS (versions >2005).
I was not able to get it.
Now, anyone of you could check on TIS (if possible) for this path?
Documents --> SI Technical --> 32 steering --> Document TSB 3220104
BMW Italy stealer, of course, will not provide it to me
Many thanks again.
      07-20-2007, 07:24 PM   #2
JC5
JC5's Avatar
Drives: 2004 Z4 3.0, 2003 VFE 530
2003 z4 3.0  [0.00]
2003 z4 3.0  [0.00]
Many of the dealers here in the US don't know about the TSB. It's in the BMWNA system, but from what some service advisors say it can be a little difficult to find.
