      10-03-2017, 04:46 AM   #1
M-Cast
M-Cast's Avatar
Drives: 2007 M Coupe
2007 E86 Coupe  [0.00]
2006 Z4 3.0si Coupe  [6.00]
2002 330 CI  [0.00]
2018 BMW 240M  [0.00]
2007 M Coupe  [10.00]
New 3.4 Stroker Build has started
At my last track event we ran into a few issues and found our way home on the back of a flat bed truck.
We were due for a Vanos Rebuild, Valve Adjustment and adding Schrick Cams. The plan was to get one more weekend before starting this project. Unfortunately, we only got through the first day and started experiencing a loss of power on my last laps. It was not a surprise to hear the dreaded rattle in the front of the engine and we just got towed to the shop.
After further investigation, we discovered a slung a bearing as well. That was the last thing I wanted to hear, but it became evident that this would be the best time to take things up another notch.
To start off with, I want to be clear, I take my car to the track regularly and my objectives are more focused on reliability and mid range power. This kind of usage does not work well for superchargers, leading to why I chose to go with a 3.4 Stroker. I found 2 different kits, Lang Racing's & VAC's and after speaking with both groups went with Lang's kit.
Lang Racing's kit is a little over $7,000 and includes
  • Billet S54 95mm Stroker Crankshaft
  • Carrillo Rod Set
  • CP Pistons - 111.5CR - 87.25mm Bore - Interrupted Poil Ring - 20 mm Wrist Pin & Pin Buttons
  • Clevite Rod tri-metal rod bearing set for widened S54 crankshaft
  • ARP Main Stud Kit
We are also upgrading the intake, adding a CSL Airbox evolve CSL airbox with this upgrade replacing the AFE cold air intake.
We are also going to be replacing the oil pump and cooler to ensure there is no metal in the system.
Prior to finding the bearing issue we added these upgrades.
Schrick Camshaft Set (S54) - 288/280 12.5mm Lift & Rocker Arms
Vanos Upgrade - Full Beisan kit with a TT C300 hub upgrade
Existing Upgrades
Once the crankshafts get delivered, I will start giving you guys updates as this is going to take about 12 weeks to complete. My Goal is to end up with around 425 hp at the crank with 365 - 380 at the wheel.
Mirko182.00
Arsonism158.00
      10-03-2017, 05:04 AM   #2
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Nice choices! Who's going to do the work for you?
      10-03-2017, 05:56 AM   #3
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
The Machine Shop I am scheduled for is Grimes Automotive Machine and the installation is Harrison Motorsports. www.HarrisonMotorsports.com
They have been doing all the work on this car since I purchased it. Very lucky to have a number of great shops in my area who all do great work.
RobinsonRacing.net
CarbonSignature.com
      10-03-2017, 12:47 PM   #4
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Sorry to hear that but excited to see the results!!!! So much want! Gl with your project!
Instagram: ariusen26
Youtube: Track vids
      10-03-2017, 01:32 PM   #5
FD3S
Drives: BMW Z4M
Good luck with your project! I can't wait to see the results...
Who will do the tuning btw?
      10-03-2017, 02:56 PM   #6
angelr
I wanna do the same....have you considered injectors?
      10-03-2017, 05:10 PM   #7
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
I have spoken with a few people about upgrading injectors and both said the same thing, it's better to stay with the OEM. I was thinking about going with larger throttle bodies, since I was moving to the CSL air box.
      10-03-2017, 06:14 PM   #8
angelr
Hmm, just playing devils advocate but I think they're close to capacity with an aggressive big cam/intake setup.
I'd be curious to know who said that...TTFS and Lang had a customer that ran out of injector on one of his strokers.
http://www.m3forum.net/m3forum/showp...postcount=1475
http://www.m3forum.net/m3forum/showp...5&postcount=12
      10-04-2017, 05:50 AM   #9
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
If you look at the set up these guys have, that would make sense he is running a 292/282 cam with a 14.5 lift and a larger stroke. My bet is they are running a 98 mm stroke and that is pretty aggressive and looks more like a track set up.
Both Lang and Harrison Motor Sports both told me the same thing based on my cars set up. Currently we are planning on 1st overbore, .25 and 11.5:1 compression, stock valves, using Shrick 280/272. Utilizing the 95mm a larger bearing set.
I am thinking about upgrading to a stage 2 cylinder head, adding larger throttle bodies, which I think would call for larger injectors. I am sure things will change as we get deeper into this.
SaltyNC369.50
      10-10-2017, 11:20 AM   #10
mattfwalters
mattfwalters's Avatar
Drives: 06 Z4MC (Sepang/Sepang/insane)
This is going to be brilliant. Can't wait to see the results. Good luck with the build!
      10-10-2017, 09:31 PM   #11
Vanne
Vanne's Avatar
United Arab Emirates
1624
Drives: 2007 Z4MC
staying tuned.. *pun intended*
can't wait to see how this turns out
Powered by
      11-20-2018, 01:51 PM   #12
rueyme
Drives: red z4
Any updates to this? I'm exploring engine builds to do while it is winter season
      11-20-2018, 01:59 PM   #13
Grumpy Old Man
Grumpy Old Man's Avatar
Drives: Porsche 993, 2015 MB GLK
Yeah, we kind of got left hanging. Said it'd be 12 weeks.
rueyme57.50
      11-20-2018, 02:14 PM   #14
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Build thread in another section documented all of it:
https://www.zpost.com/forums/showpos...&postcount=131
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
      11-20-2018, 06:31 PM   #15
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
You can also see most of it here.
We are now pushing 437hp/386 wheel hp / 274 ft lbs torque.
This is an awesome setup and the power on the track is unbelievable.
https://www.facebook.com/pg/MCast2016/photos/
https://www.instagram.com/whmcast056/
