02-27-2012, 03:57 PM | #199 |
instagram 997turbotom
279
Rep 7,377
I bet you could replicate the VT2-500 to VT3-600 upgrade by ESS.
18psi on the Vortech with 9.5:1 compression, tuned on Pro-EFI too bad its out of my price range right now
02-27-2012, 04:25 PM | #200 | |
Rep 59
Clutch was custom built for us by Southbend. Similar materials in the disc as the HPF clutches, this particular one most closely resembles the stage 3 variant they offer. Obviously from looking at it, it's not the same as an HPF clutch, it has a few additions. Flywheel also made by Southbend, made from billet steel. After much discussion we opted for a single mass flywheel with a 20% weight reduction over the stock DM flywheel. Stock FW weights 24.55lbs, this one is right at 20lbs. If you have any other questions specifically let me know and I'll do my best to answer them This couldn't be further from the truth, no harm in doing things right THE FIRST TIME! He knows he's going to drive the car hard, he trusts us with the work being done to the car, and wants to pick the car up ready for anything! FL isn't quite "around the corner" from Cali if it was to need to come back. If you can afford it, or justify the money spent, no harm in doing everything at once! |
02-27-2012, 04:40 PM | #201 |
279
Rep 7,377
oh no doubt, but either way you slice it, its not a cheap build. But you know what? I bet it'll still be cheaper and quicker compared than many other sports cars
02-28-2012, 05:24 PM | #202 | |
Rep 147
Trevors car being about 400lbs-500lbs lighter running a twin scroll manifold, and the GTX35R turbo would have been surprising everyone there.. I think it would have hung with all the big dogs. This is the car I mentioned above vs. a Hennessey 700 GTR (700hp to the crank).
849rwhp/629rwtq - 10.56@142.7 - 5.6s 60-130 on street tires on 19x10" wheels - manual 6spd |
02-29-2012, 03:25 AM | #204 |
Rep 1,603
Drives: Imola Red Z4MC
man that video... makes me lean towards turbos so hard
///M - Some Mods 'N Stuff
03-07-2012, 04:21 PM | #205 |
Rep 59
Little by little, getting closer!
Fuel tank cap Medusa Three bulkhead fittings, <3 E85 Surge tank mounting holes drilled & tapped, 4 grommets for lines in/out Tank mounted, OEM tank feed to surge and surge overflow to OEM tank installed Clutch & Flywheel installed - new throw out bearing, pilot bearing, pivot pin, and clutch fork DSS axles installed UUC Evo 3 Short shift Dual 6an feed to rail = dual filters Enjoy! -Shawn- |
03-07-2012, 04:58 PM | #206 |
Rep 5,327
Awesome....... No stone unturned :-)
03-07-2012, 06:12 PM | #207 |
60
Rep 970
03-07-2012, 07:10 PM | #208 |
Rep 1,663
Are the axles only to handle the extra power, or do they also have a weight advantage over stack?
Also, no interest in putting in a carbon fiber driveshaft? There's 3 companies in FL that make them.
03-07-2012, 11:52 PM | #209 |
Rep 503
Drives: Z4 M Coupe
Is that a DSSR? I thought UUC didn't make those for our cars yet.
03-08-2012, 12:09 AM | #210 |
60
Rep 970
Anyone with questions on pricing, inquiries or just have a question about something please feel free to email me! Andrew@lutzperformance.com |
03-08-2012, 12:17 AM | #211 | |
Rep 503
Drives: Z4 M Coupe
03-08-2012, 08:17 PM | #212 | |
Rep 147
Regarding the axles they're actually heavier.. but significantly more durable. Our cars (E46 M3, Z4M, etc) all snap axles pretty easily under wheel hop. This is more of a precautionary step that Trevor took with those axles. Some people have had no issues with their stock axles and turbo E46's.. but quite a few have snapped them with even the slightest amount of wheel hop.
03-09-2012, 04:13 AM | #213 | |
Rep 5,327
03-16-2012, 06:10 PM | #215 |
Rep 1,603
04-18-2012, 04:22 AM | #216 |
Rep 503
Drives: Z4 M Coupe
Any updates on this build?
04-18-2012, 06:21 AM | #217 |
Rep 5,327
its gone wayyy to quiet in here for my liking :-(
