      03-04-2012, 11:35 PM   #1
iPhoneEngineer
Drives: 2007 BMW Z4 M Coupe
Recommended camber for a daily driver.
I'm going to get an alignment soon, and couldn't find any relevant threads (pretty surprising...sorry if I missed something obvious).
What camber do you run? I have camber plates and have been running -2.5 or so when I was commuting up and down a windy road, but now that I've moved and it's mostly straighter driving, I need to choose another value to save the tires.
      03-05-2012, 03:54 AM   #2
l4zy
l4zy's Avatar
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
2017 BMW M3  [0.00]
2015 BMW i3 REX  [0.00]
1995 BMW M3  [10.00]
2013 BMW X3 xDrive35i  [7.00]
If it doesn't cause any clearance issues why not go with original specs?
      03-05-2012, 08:33 AM   #3
3002 tii
3002 tii's Avatar
2288
I have 2.5 and I haven't noticed any crazy uneven wear... I'd think 2.5 is perfect for daily that seems some spirited driving here and there.
Follow for latest mods
      03-05-2012, 12:25 PM   #4
johanness
Drives: 2008 Z4MC
^^^ this. Toe is the bigger factor when it comes to tire wear
      03-05-2012, 08:06 PM   #5
iPhoneEngineer
Ok, very cool. Yeah, to the first post: I have heard many say that the E85/E86 pretty much universally benefits from adding a pretty substantial amount of negative camber. However, I really wasn't sure what makes sense for a mostly road-going car. I will stick with -2.5 for the impending alignment. Thanks!
      03-11-2012, 07:26 PM   #6
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
Is it the same camber settings in the front as in the rear? I'm curious myself as I'll also need an alignment soon.
      03-11-2012, 09:15 PM   #7
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
-2.5 is a bit aggresive for the rear
      03-11-2012, 10:21 PM   #8
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
went through some of my old notes looking for specs on this, but couldn't find the ///M ones.
for comparison though, here are stock sport non-///m E86 alignment specs
Front Camber = range of -0.5 deg to -1.4 deg
Front Toe = +0.05 deg to +0.18 deg (toe in)
Rear Camber = -2.6 deg to -3.1 deg
Rear Toe = +0.17 deg to +0.37 deg (toe in)
on my 3.0si with eibachs i was at -1.5 in front and -3.1 in rear (both camber). toe for both was set at mean for both front and rear. no adverse tire wear to report.
i can't imagine that the ///m alignment is too far off from the above specs. i also agree that most premature tire wear is caused by ill-adjusted toe.
      03-12-2012, 02:20 AM   #9
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
Perfect! Thanks!
      03-12-2012, 03:43 PM   #10
Incompatible
Drives: 07 AW Z4C 3.0Si
...on my 3.0si with eibachs i was at -1.5 in front and -3.1 in rear (both camber). toe for both was set at mean for both front and rear. no adverse tire wear to report.
Almost identical set up on my 3.0Si sport with eibachs. I went -1.3 front and -2.5 rear camber. The change in the handling was noticeably inproved and the car feels so much more planted in the corners over the oe sport setup.
      03-12-2012, 03:49 PM   #11
v3.2mc
Not a New Member
v3.2mc's Avatar
planted indeed... eibach's FTW!
      03-12-2012, 10:56 PM   #12
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
Anyone know what the stock camber is for the 3.0si sport suspension? Trying to figure out how much more camber I can add to the wheels and if that means I should go with 18mm spacers or 20mm spacers in the rear and 12mm spacers or 15mm spacers in the front.
      03-13-2012, 10:24 AM   #13
v3.2mc
Not a New Member
v3.2mc's Avatar
yep. see post #8 above.
      03-13-2012, 12:10 PM   #14
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Front specs are pretty close to what an ///M would run, except it's -.7 not -.5.
Rear specs, however, are way off for an ///M! There's a bit difference between the 3.0 and the ///M settings rear.
Rear specs for the ///M are -1.6 to -2.1 with a total toe-in of .47 - .57.
I'd run towards the low end of the negative camber settings rear, and max out the front camber within the stock settings or just beyond (e.g. -1.5 to -1.8) with minimal toe-in within the stock range.
A full discussion of the stock alignment for the ///M can be found here. See post #4 by Jmillet in particular.
      03-13-2012, 12:29 PM   #15
v3.2mc
Not a New Member
v3.2mc's Avatar
well found, finnegan!
      03-13-2012, 05:49 PM   #16
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
Btw, got pics of your car so I can check out the stance?
      03-13-2012, 05:49 PM   #17
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
      03-13-2012, 05:57 PM   #18
v3.0si
v3.0si's Avatar
Drives: '08 Z4C 3.0si
check out my pics page under "v3.0si - now with 313's". lots of pics there.
      03-13-2012, 06:00 PM   #19
v3.2mc
Not a New Member
v3.2mc's Avatar
^ yeah ... what he/I said.
stupid phone.
      03-13-2012, 06:07 PM   #20
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
I guess what I was trying to get at was not the range, but the exact setting it comes in from the factory. I'm trying to figure out without actually having my alignment measured out if I still have more room for camber. Maybe it is set right in the middle of the range???
      03-13-2012, 08:02 PM   #21
Finnegan
Finnegan's Avatar
I think the rule on this one is that there is no "exact setting" as it comes from the factory. I really don't think they are all that precise. If you took several brand new cars with 0 miles in for an alignment I'd expect the results to come back more or less in the specified range. Some would probably even be outside the range.
The range is hypothetical anyway. On my car, the max of the stock range on the front is -1.4. Most folks can't get the alignment to much past -1.0 without camber plates or the Turner washer kit (or with the car lowered). Bottom line there's no way to know how much you have to work with until you have it aligned.
My advice? First, get it aligned, ask them to max out the negative camber up front and keep it even side to side, and then consider what you want to do from there. Second, consider what the stock offsets are, and what your current offsets are (if not stock wheels) before selecting spacers. Changing from the stock offsets can have a very real adverse impact on handling due to how it changes the scrub radius. The Hack does a great job of explaining scrub radius in this thread, and why it matters (my summary of the discussion is in post 19 FWIW).
      03-16-2012, 11:08 PM   #22
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
Gotcha! Thanks for the advice. I read up on that thread regarding scrub radius. I gotta tell ya, after reading about scrub radius, makes me not want to put on spacers and get tires that are bigger than stock.
