11-01-2012, 12:58 PM | #1 |
Rep 240
Drive to CT this weekend
Fellow Nor'easterners, I must drive to Connecticut from ATL this weekend, what obstacles will I be encountering that I must watch out for? Please advise. Thanks
11-01-2012, 07:00 PM | #5 |
Retired Paratrooper
Rep 146
Why run up on 95.
Take 77, 81, and 78 to 95 and bypass Richmond, DC, Baltimore, Philly and all the crap traffic that comes with those areas. Difference in miles is only 15 miles longer and a heck of a lot nicer drive. And if you want you can bypass the GW bridge and take 287 to 87 and bypass NYC and their huge headache too. This does add another 18 or 19 miles if going up to Hartford. Have a safe trip. |
11-01-2012, 11:45 PM | #7 | |
Retired Paratrooper
Rep 146
FWI- 3 crossings to consider across the Hudson river running up 95 These crossing are fairly close to each other providing access to New York, Manhatten and the Bronx George Washington Bridge is open, but the Holland Tunnel is closed and the Lincoln Tunnel is now restricted to HOV3 only between 6am and midnight. Most of the traffic that was split between those three crossings is now pretty much forced to the GW Bridge. You may want to consider crossing the Hudson further north on the Tappan Zee (I 287) |
11-02-2012, 10:27 AM | #9 |
Rep 12,565
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.22] |
I drive on 95 everyday from gwb to Stamford and gas is scarce. In past couple days I filled up at Stamford because westchester was low but now even Stamford is having its share of long lines. My best advice is to fill up every chance you get.
11-02-2012, 08:00 PM | #10 |
Rep 704
Drives: '08 MC
Best advice, avoid this area entirely right now. its getting worse, not better. I live just off Route 1/9, south of the GWB. if a station has gas, you'll be backed up 1 mile+ just to get past it. And you wont want to wait in a 90 minute line if you need it.
11-02-2012, 10:05 PM | #12 |
Rep 704
Drives: '08 MC
I am very sorry to hear this, sincere condolences to you and your family.
suggest following pmmjarrett's advice above. aim for 287 and the tap bridge, not the GWB. I dont know how bad the Merritt in CT is vs 95 once you get into CT, but either way your en route to new haven. Maybe even cut over east, further north, perhaps on 84. Just avoid as much of NJ as possible cutting thru here.
11-02-2012, 11:11 PM | #13 | |
Retired Paratrooper
Rep 146
Running 81 to 84 only adds 40 or 50 miles. Good route too. FYI Pilot and Flying J travel centers are reporting all of their locations are up and running after Sandy. You can use their fuel price guide to help plan your trip. Gives you each travel centers location as well as the price of their fuel.
Retired US Army 82nd Airborne Division.
- There's no such thing as a perfectly good aircraft. I have the option to get out while you have the pleasure of riding it in. |
11-03-2012, 10:05 AM | #14 |
Rep 407
Really sorry to hear about your father.
If you need gas on your way up, I've heard from friends that the area around exit 7 off of the NJ Turnpike has plenty of operational gas stations with no lines. |
11-07-2012, 08:47 PM | #15 |
Rep 240
Just got back from CT about 45 minutes ago, the route suggested was perfect, no problems with gas or the Moupe. Thanks to all for the condolences on my dad's passing. He was 93 and had one helluva run.
