      09-18-2010, 12:02 AM   #1
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Exclamation Help w/ SS Race Mufflers Install
Hey guys, so I bought SS Race mufflers (mufflers-only) and was planning on installing over the weekend. However, after having taken a closer gander, I'm worried that I might actually need the x-pipe in order to install these
Cuz the stock setup uses flanges, and the SS mufflers don't have any. I'm assuming they use clamps? Well, the seller didn't provide me clamps, so I don't know what to do to secure the piping together into section 2(?). The end of section 2 also has a little lip to it, where air might leak out? Sigh...should've gotten the x-pipe
Can anyone chime in on this?
      09-18-2010, 12:36 AM   #2
DanMcoupe
DanMcoupe's Avatar
Drives: 2006 Red Mcoupe/2012 AW 535
I bought my SS race slightly used from a member in this forum. It came with the flanges and It's easily bolts on... just like stock.
      09-18-2010, 12:42 AM   #3
mfanatic325
///M-fanatic
Taiwan
193
What the...really? hmm...well perhaps the ones I bought were from a "full kit", where SS sent the mufflers AND the x-pipe together, in which case the mufflers are supposed to slide/sleeve over the x-pipe (section 2 portion), and then clamps are used to tighten them?
edit: did you keep the stock section2? Or did you get the x-pipe as well?
      09-18-2010, 01:30 AM   #4
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
Well what I offered you will solve that. only thing is I need other 2 or 3 weeks for that, and I will send you pictures.
FYI: Section 1 = S pipe or middle section
Section 2 = X-pipe
      09-18-2010, 01:42 AM   #5
mfanatic325
///M-fanatic
Taiwan
193
Ah cool yeah, I'll wait for those pix. Yeah, I thought that was the case. Good thing I got the sections correct in my head to begin with
Right now, I'm just having a mis-match issue in terms of trying to fit the SS Race mufflers' "sleeve" style to the OEM section2's "flange" style. Mainly because I can't re-use the flanges from the OEM mufflers, and also the fact that OEM section2 has a flared lip (like a trumpet), whereas the SS Race's sleeve doesn't have such a lip.
