      07-15-2009, 10:54 AM   #23
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Any videos of the intake sound yet???
You have to be 100% behind someone before you can stab them in the back.
David Brent
      06-13-2012, 03:53 AM   #24
tikamak
Lebanon
58
I installed my afe intake and there's something i noticed, when going uphill or even when mashing the throttle on 2K RPM for example (or a high throttle) the intake tend to make a tinny growly sound that tends to go away and transform to a kind of a howl on higher RPMs.
Is this normal? i don't like that tinny sound, i just want the induction howl and growl
      06-13-2012, 06:20 AM   #25
GammaZeta
Drives: 1
Yeah, I noticed the same thing when I had mine, which is one of the reasons why I sold it. It sounded nice at 5k + but didn't impress me with the RPM's below that.
      06-13-2012, 06:31 AM   #26
tikamak
Lebanon
58
Sounds very tinny under 5K. Like a badly designed intake, although it is quite good.
I am thinking of modifying mine to eliminate that kind of rattle and leave the induction sound.
I think that i will need vibration dampeners, i will put on the intersection parts of the housing and the chassis which should reduce this effect and leave the induction sound.
      06-13-2012, 10:18 AM   #27
johanness
Drives: 2008 Z4MC
No 'tinny' sound here.
Were either of you tuned for the intake? (ESS, AA, etc)
If not you weren't experiencing its potential either
      06-13-2012, 10:37 AM   #28
gferil
gferil's Avatar
30
Drives: 06 Z4MC
When I had AFE on mine it never made any tinny sound...only deep and loud bass!
I wonder if something is rubbing due to vibration or if the cover isn't on tightly?
      06-13-2012, 11:03 AM   #29
Pheonix
2007 BMW/Z4MC  [0.00]
Same here! No tinny sounds that i could hear
      06-13-2012, 11:13 AM   #30
tikamak
Lebanon
58
Maybe my choice of words is wrong.
It's still a loud growl but it's like an american muscle car type of a growl, not CSL snork type.
To rephrase, you hear the deep growl but there's an extra sound that seems like metal on metal shriek
      06-13-2012, 02:59 PM   #31
GammaZeta
Drives: 1
+ 1.
      06-13-2012, 04:05 PM   #32
tikamak
Lebanon
58
The metal shriek is the one i hate, i want a CSL grunt and snork like the car is a badass instead of a fake v8 sound
      06-13-2012, 05:01 PM   #33
gferil
gferil's Avatar
30
Drives: 06 Z4MC
I dunno...I honestly never heard any sound resembling a metal shriek when I had my AFE, and I listened very carefully through all types of driving and loads...
      06-14-2012, 02:03 AM   #34
tikamak
Lebanon
58
Did you reuse the stock ball like mushy bushing to mount the case of the AFE ? because i am thinking about puttin this part underneath the afe housing.
I feel that the metal to metal contact of the housing and the chassis is the reason why i am hearing this metallic sound when hard throttling on low RPM
      06-14-2012, 11:32 AM   #35
gferil
gferil's Avatar
30
Drives: 06 Z4MC
Yep, kept that mushy thing under there cause I thought removing it would cause rattling.
      06-14-2012, 11:55 AM   #36
Pheonix
Which filter do you have? Oil or Dry? The "shriek", noise is probably from the air rushing in?
      07-06-2012, 10:09 AM   #37
knsaber
knsaber's Avatar
Drives: 2007 BMW M Roadster Imola Red
I just installed the aFe and made a recording with a Tascam DR-05 recorder. I don't feel the aFe is as deep or growly as I'd like it compared to my E46 K&N cai.
      11-07-2020, 10:09 PM   #38
filtercoffee
I like Coffee & Z4s.
106
Drives: 2007 Z4MC
2007 BMW Z4MC  [0.00]
Thanks for this post. After a brief experiment, I've found that this mushy thing plays a huge role in toning down the tinny sound from the aFe intake.
Here's what the mushy thing looks like from the underside:
View post on imgur.com
It's part #13717539903 here: https://www.realoem.com/bmw/enUS/sho...diagId=13_1174
I found that the aFe housing fits much better without said mushy thing, but the sound was tinny. Almost like you could hear the valve metallic noise amplified. With the mushy thing, the housing doesn't seat quite right, but the tinny noise is gone and the low growl is heard more clearly. I'm so glad to get rid of the annoying tinny noise!
Here's how it currently sits in my setup. Was yours similar?
There was a bit of a fitment issue after adding the mushy bushing. Of the two mounting points to the body, i could only comfortably affix one, due to the increased height of the housing due to the mushy bushing. The second one I left like this:
