      03-31-2013, 11:52 PM   #1
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
265/35/18 front GURUS NEEDED!
Hey guys, I got a set of 18x9.5 +35 squared with 265/35/18 tires on. Fronts rub the shock tower without a spacer. Before I order one, is 5mm enough or 10mm recommended? Eventually im sizing down to 255 squared but the tires on the wheels currently are still good. THANKS!
      04-01-2013, 12:21 AM   #2
dorifto88
Drives: 88 Nissan Pathfinder
what suspension do you have? I used a 5 in the front only because the wheel physically hit the coilover without it.
      04-01-2013, 12:31 AM   #3
i2ichal2dZ4M
stock suspension, turner camber shims pins removed
      04-01-2013, 12:57 AM   #4
dorifto88
i think you are going to need some more negative camber than removing what the stock pins might allow, but just try the 5mm.
      04-01-2013, 01:15 AM   #5
i2ichal2dZ4M
im at -2.5 fronts
      04-01-2013, 10:21 AM   #6
a_riddler
Bimmer Noob
a_riddler's Avatar
5mm should be fine. For a 265et35 front, I found that a minimum -2.7 is needed. congrats on the new wheels!
      04-01-2013, 12:56 PM   #7
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
5mm minimum of space between wheel/tire and strut is recommended by Turner when using camber washers.
Do the wheels/tires contact the strut only under load? In other words, is there space between the strut and wheel/tire when parked?
If the wheels/tires are in contact with the strut with car parked you're going to need more than 5mm. If you go 10mm make sure it has a hubcentric lip like these. Otherwise, the 5MM should be fine.
Max I've found I can get with stock suspension with 2 washers is about -2.6. YMMD, but you may need camber plates to run that wide a tire. Plates would probably omit the need for spacers as well, assuming you removed the camber washers. Camber washers push the bottom of the strut outwards, decreasing the amount of space available between strut and wheel/tire.
      04-01-2013, 11:17 PM   #8
i2ichal2dZ4M
thanks guy! was able to borrow a set of 5mm and a set of 10mm. 10mm looks alot more promising and has more cushion. 5mm looks like it will cut it very close. My ideal setup is 255 squared i need to waste these 265 tires.
      04-01-2013, 11:20 PM   #9
i2ichal2dZ4M
my plan is to eventually to get coils with camber plates, but im learning the car on the track a step at a time. first was completely stock for a couple track days. now i have upgrade my tires/wheels and aligment settings. dont want to dive straight into mods.
      04-02-2013, 12:11 AM   #10
Finnegan
Finnegan's Avatar
Totally agree with your plan.
      04-09-2013, 07:39 PM   #11
kklin
Drives: BMW Z4 M Coupe
I have the same size wheels and tires (old Star Specs) in front with 5mm spacer.
All detailed here with pictures - kklin's Z4 M Coupe for SCCA BSP (road tire)
      04-09-2013, 09:25 PM   #12
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
A little offtopic but - you were only able to get as much as -2.5 with turner camber shims and pins removed ?
      04-09-2013, 09:30 PM   #13
Finnegan
Finnegan's Avatar
I'll weigh in. Two washers, 235/40 265/35, -2.6. Stock suspension, shocks full inboard.
      04-09-2013, 10:05 PM   #14
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
-2.3* Here with 2 washers running 235/45, 265/40
Probably going to be removing the shims here soon though.
      04-09-2013, 11:07 PM   #15
i2ichal2dZ4M
only 2.5 up font. one side would go to -3 but other side maxed at -2.5. im on stock hight, havent rubbed yet!!
      04-10-2013, 10:43 AM   #16
a_riddler
Bimmer Noob
a_riddler's Avatar
Sexy, nice job!
      05-08-2013, 07:19 PM   #17
F360C
Drives: E86 S54
Did the 5mm shims solve your issue?
07 Z4 M Coupe AW/IR
      05-08-2013, 08:10 PM   #18
i2ichal2dZ4M
Yes it did, for now atleast, since i'm on stock height. Already went to a track day and no rubbing whatsoever!
