      05-14-2015, 12:14 PM   #1
3002 tii
3002 tii's Avatar
2282
TCK DA Koni Adjustment Knobs Won't Fit
Just picked up a new set of TCK DA's for my 3.0si. Install went fine but I noticed the top adjustment knobs won't fit because the strut towers openings come in contact with them. The only way to get them to fit would be to dial out some camber which is something I don't want to do. I managed to make adjustments using needle nose pliers but is there a better solution?
I found this old thread that dealt with the same issue. Any idea where I would find a tool like this? Else I might just cut out the tip of a flat head screwdriver. Apparently Ron Stygar used to make a deal for this very issue but he's no longer selling (or reachable).
Follow for latest mods
      05-14-2015, 06:27 PM   #2
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
Post if you find one please. I use needle nose pliers as well.
Forgot to mention, get http://www.rogueengineering.com/rogue/KONI_ADJ.html. Makes adjusting the rears a no brainer.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      09-15-2015, 12:33 PM   #3
lakefront
Drives: 2017 Macan GTS
TC Kline sells a tool like that made out of an old nut driver.....works great.
