01-27-2015, 04:55 PM | #23 |
Rep 164
Drives: 08 Z4M Coupe
I'm sorry to hear about your ordeal, but glad to know you figured it out. It is a bit concerning however that AP would let a rotor leave the factory out of true.
01-28-2015, 12:28 PM | #24 |
Rep 5,328
never seen such an issue with ANY of these AP kits over the past decade, the CSL forum over here in the uk must have the most AP kits and the hardest used kits out their and nothing like this from a box fresh kit, but i suppose not everything can be perfect, id hope customer service would be better across the board to be honest.....
HOWEVER.... during a PM conversation it did come to light that the op MAY have some install issues as the caliper needs to be shimmed very specifically to centre over the rotor, this shimmed was not completed or completed correctly, the car was then run with the caliper out of alignment, again not saying this was the issue but i feel it should be highlighted. i have never had an issue with my ap bbk and i beat on this setup hard in the summer at all day track sessions, I've had the rotors glowing, the rotors turn different colours and still i drive home with a judder free setup. I took meticulous attention to detail on the install of my kit and it has been perfect from day one. after a full day of braking from high speed the rotors turned deep dark blue one of the many ALL day sessions done with my AP bbk. WHATEVER i say, the op deserved far better customer service than he received and i REALLY hope he is happy with his bbk now,
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 01-28-2015 at 01:02 PM.. |
01-28-2015, 02:31 PM | #25 |
Rep 10,661
01-28-2015, 02:47 PM | #26 |
10841
Rep 4,891
Also the turning (as opposed to grinding) for such a floating rotor at a 'normal' garage is imho also a disaster waiting to happen (turning a fixed or floating rotor is a completely different thing on a rotorlathe). I'd never let them do that on such expensive and new condition disks.
But the biggest problem was obviously the aftersales. A brand with such a name/pedigree as AP should just swap the rotors no quenstions asked. A satisfied customer is everything in this small tuningworld&time of interwebs 'n forums...... And I mean its a wear product, limited life.... A satisfied customer will be coming back when he needs new disks..... Also if you have pad deposit or even some rust, that causes shudder, but wears away rather quickly and its something you see. These rotors looked clean&fine.
01-29-2015, 07:42 AM | #27 | |
Rep 5,328
middle paragraph is on the money for me, i don't care who problem this was AP should have handled this in a very different way IMO.... so for that OP, i really hope your experience is better from now.
01-29-2015, 08:12 AM | #28 | |
Rep 924
Thanks guys for the best wishes. I forgot to quote the rotor specialist regarding the runout:
