      05-17-2015, 07:14 PM   #1
08z4mroadster
Drives: Z4MR Grey
KW V3 noise
Hi All
Does any Z4M owner has experience with KW V3 making noise while you driving or passing speed bump?
      05-17-2015, 08:44 PM   #2
Mirko
Mirko's Avatar
Define the noise. Creaking, whoosh from air, thump, bump, etc.
They are nosier than stock suspension. Did you tighten the end links tight enough? That will make a thump sort of sound at low speed and over bumps.
      05-18-2015, 12:34 AM   #3
2282
End links, play in fcab, rear shock mounts...
      05-18-2015, 05:03 AM   #4
Beedub
my clubsports are silent. after a hard track day when everything hot i can hear some noises but on normal road use, nothing at all, just my teeth banging together.
      05-18-2015, 06:26 AM   #5
Drives: M2 Comp
Mine were never silent on anything but a smooth surface.
      05-18-2015, 11:14 AM   #6
Beedub
mine are silent 98% of the time id day.... and I've only heard the noise I'm describing on the road that leads off the track, its like a bumpy dirt track. i love these coilovers!
      05-21-2015, 11:52 AM   #7
08z4mroadster
Drives: Z4MR Grey
Thanks All,
Comparing with KW V3 and BILSTEIN PSS10 now. KW doing 22% off special at my local dealer now. It's cheaper than PSS10 in here, but i like the BILSTEIN that adjustable dampening knobs from the bottom.
If price is the same, the KW V3 would that be better value than BILSTEIN?
Thanks for all answer.
