      02-08-2013, 06:45 PM   #67
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I just installed Rogue RSM when I converted back to lower spring stock shocks. It is a good time to change it out since the rear trunk area is apart.
I like camber plate GB too. Might as well go all in :-)
      02-08-2013, 08:36 PM   #68
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by beta View Post
Also, I'll probably do a group buy for Vorshlag camber plates as well, so people can get full setups for a good price. If there's a vendor interested please PM me. Otherwise I'll start talking with Vorshlag and see where it takes me.
Maybe Apex?
http://www.zpost.com/forums/showthre...light=Vorshlag
      02-08-2013, 08:40 PM   #69
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
With RSMs You will need to know the shaft size of the Ohlins.
My Clubsports have a larger shaft than OE & I have a different size RSM
      02-08-2013, 09:31 PM   #70
RobMCoupe
RobMCoupe's Avatar
60
Rogue RSM can accommodate 10/12mm. I need to get new nuts. I have to check the RT kit shaft diameter. It should be the same for Z4M.
      02-08-2013, 10:09 PM   #71
604skyline
Drives: 2020 M2 CS
hope its ok I stick my nose in this thread. I for one am definitely interested for sure.
some general questions; what makes ohlins so good?
how is this kit going to compare to the moton and/or motion control kit that are in the $6,000 range
thanks.
      02-08-2013, 11:22 PM   #72
beta
Drives: 2006 M Roadster
I'll contact them if Vorshlag doesn't get back to me or if they're not interested. Thanks.
Good to know. I'll ask.
thanks.
For one thing they use linear springs and monotube shocks. Another big advantage is we're going to get full testing so its a real engineered solution. Every other coilover was built without extensive engineering (including the race suspensions you mention, those you need to ask for the specs you want).
The only kit that I'm aware of that was developed properly for our car was KW, but they use progressive springs and twin tube shocks (clubsports use linear in front but still progressive rears).
The kit would compare to an MCS single adjustable non-remote kit. You can't really compare it to the higher end kits, as those are for motorsports. So they're supposed to be rebuilt pretty often and are not meant or warrantied for street use.
The R&T kit also has the DFV Valve, which allows it to absorb high speed damping for optimal performance. Read up on that link.
From that same site:
The choice of materials used is one of the key factors behind Öhlins success. Each component is surface treated to ensure reduced friction and superior performance. The piston shaft and damper walls are micro-finished and plateau honed for optimum lubricity and low friction coefficient. This attention to detail is the same across the entire range of Öhlins products. Without this fine surface finishing, excessive friction can reduce the compliancy of the damper causing a loss of function.
Damping rate on the R&T units is fully adjustable and ties compression and rebound together as a matched setting, meaning that in 99% of cases, the units will work superbly, straight ‘out of the box’ with only the smallest adjustments required to suit the car or drivers individual preferences. Despite what other suspension manufacturers may tell you, comfort is king, even when you are trying to set-up a competition machine. Our vast experience on events like the World Rally Championship and Isle of Man TT races has shown us that the fastest drivers and riders are those that aren’t being shaken to bits as they go flat out. The ‘science of compliance’ is a hugely important part of our design work.
And last but not least, is durability. But hey, we’re Swedish, so chances are you have already guessed that we’re used to building components that survive one of the toughest environments in the World. The carbon steels bodies are salt spray tested and can service 240 hours of abuse, whilst still retaining function. Don’t let those stunning race car looks fool you. These are real-world units for daily driven cars.
These shocks are so good the perfectionists at Singer used them.
I'm sure there are more reasons and hopefully others will chime in.
      02-09-2013, 08:33 AM   #73
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Is there any info on how they would mount the rear springs?
There are a few different ways, adjusters etc. & this is often an issue with keeping preload on linear springs.
Kits like GC hang loose when the suspension is at full extension.
      02-09-2013, 09:11 AM   #74
beta
I'm guessing it's adjusters like the 1 series.
I can add it to my list of things to ask. So far I'm going to ask about RSM and camber plate specs (spring/shaft/etc.).
Any other questions you guys have let me know.
      02-09-2013, 11:09 AM   #75
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
That's PERFECT!
It's the same as the JICs I had.
They have an adjustment on the damper tube that lets you adjust the preload on the rear spring.
With this design, they will definitely not hang loose like GCs.
These are going to be amazing
      02-09-2013, 02:43 PM   #76
beta
That's PERFECT!
I can't wait! Best coilovers on the market. This is a once in a lifetime opportunity guys, don't let it pass you by.
Confirmed:
1. beta
2. RobMCoupe
3. *censored* tentative (you know who you are )
4. Finnegan
5. zubydafa
6. aestheticstorm as long as 3200.
      02-09-2013, 03:20 PM   #77
johanness
Drives: 2008 Z4MC
I'm waiting on Rated M's dyno/AFR report, as the $ is currently put aside for FI. I'll be out for the time being
      02-09-2013, 04:13 PM   #78
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Would love to get on these. Can't do anything until March-ish.
      02-09-2013, 04:41 PM   #79
beta
Cool, let me know if it falls through. You can always do FI later, this is a one time deal
Cool should I count you in then?
      02-09-2013, 06:58 PM   #80
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Confirmed:
1. beta
2. RobMCoupe
4. Finnegan
5. zubydafa
LOL as if know one knows who *censored* is
...anxious to see what the price point ends up at.
      02-09-2013, 10:34 PM   #81
mtrhed
mtrhed's Avatar
13
Drives: 06 AW Z4MR/w211 e63 AMG/325XiT
I'm in!
      02-10-2013, 02:19 AM   #82
beta
Originally Posted by mtrhed View Post
I'm in!
Great! Looks like we won't have any problem getting to 10. I'll see what kind of discount we can get if we get to 20
1. beta
2. RobMCoupe
4. Finnegan
5. zubydafa
7. mtrhed
      02-10-2013, 07:24 AM   #83
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Another thing to add to the list; rear damper cable extenders.
      02-10-2013, 08:48 AM   #84
boydgti
boydgti's Avatar
Drives: 2007 z4m
I have ohlins on my bike and love them. I don't track my car and have H&R springs on it now. Just wondering would it be a good idea to get this set up, advantages for street use??
      02-10-2013, 08:59 AM   #85
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
There's lots of info on the 1 &3 series forums.
Essentially they're a very sophisticated setup, best of both worlds.
Better daily ride & better tack too.
      02-10-2013, 09:04 AM   #86
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
This needs to be confirmed.
Looking at the 3 series, it looks like this may not be the case
      02-10-2013, 12:32 PM   #87
beta
As Intgr8r mentions, these will ride better on the street. They also have better high speed damping (dfv). All while performing when you're driving aggressively, H&R uses progressive springs, these are linear. The materials are also much more high tech: durable and treated, salt spray tested and all that. Read the second half of this post for more info and links.
I'm upgrading from KWs if that tells you anything. According to some H&R are harsh (although there are exceptions). Harsh is always a very relative term on these forums. For some KW clubsports are harsh, but some track junkies find them too soft
Don't they have the same adjusters? other picture.
I'll definitely add it to my list of questions: RSM, camber specs and how rear springs are adjusted.
Keep it up guys! Spend some time looking at E9X reviews on these coilovers, pretty much universally people love how they ride, the excellent performance and the fit and finish of these is absolutely top notch.
      02-10-2013, 07:02 PM   #88
boydgti
boydgti's Avatar
Drives: 2007 z4m
Ill prob be in also if the price isnt to crazy
Search this Thread:
Advanced Search
