01-11-2024, 08:31 AM | #1 |
Petrolhead
440
Rep 808
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Style 108 Wheels Restoration
Ok, seriously the last expense I'm supporting on my Z4 (at least for a long...long time). After completing the brakes restoration, putting the wheels back on was just a bloody eye sore. The barrels were badly corroded and face plates were poorly spray can painted by the previous owner, pealing, and rough. I disassembled them myself - surprisingly all 80 bolts came out easily - and dropped them off at my trusted powder coating shop.
2 questions:
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
01-12-2024, 07:26 AM | #2 |
Rep 21
Drives: 2006 Z4 3.0i 6spd manual
I refinished 3 piece HRE wheels for my S4 about 12 years ago. It was recommended to use new bolts.
01-12-2024, 10:41 AM | #3 |
Rep 125
I am thinking about doing 108s myself. I love those wheels. Like you, powder coat the hub part. I am thinking about the hub part gloss black (the car is black) and then polishing the rim part to a high luster. And since the wheels are made by BBS, finding a center cap with BBS on them.
If you want to be happy for a day, drink. If you want to be happy for a year, marry. If you want to be happy for a lifetime, drive a BMW Z4!
01-16-2024, 09:55 AM | #4 | ||
Petrolhead
440
Rep 808
I don't doubt that for a second and usually what I will do for almost every bolt that comes off and back on my car (per TIS), but good god I just googled BBS titanium bolts and 80 would cost me as much as a new set of wheels. Considering the car barely does 1k per year, I'll keep the existing bolts and just monitor them. I did clean and polish them to perfection.
01-16-2024, 10:13 AM | #5 |
Rep 1,991
If it was 4 or 5 bolts I would likely replace them, but if they are in good shape, what is the chance 80 bolts will fail? Couldn't be much. Crazy that they would cost that much to replace. I didn't know they were BBS.
01-16-2024, 12:31 PM | #6 |
Get off my lawn
932
Rep 1,159
Drives: 6MT
Garage List 2023 GR Corolla [0.00]
2022 BMW X3 M40i [10.00] 2007 BMW Z4M Coupe [0.00] 2002 BMW 325xiT [0.00] 1991 BMW 318is [0.00] |
Looks like the Z4-Forum found these as the replacement (worth a call/email to confirm)
https://www.pwmotorsport.com/5x-tita...bs-wheels-copy ~$38 a set x 8 (80) is a bit spendy for the OE titanium. One could swing for a stainless steel alternative from these folks https://www.srrhardware.com/ |
01-18-2024, 07:22 AM | #7 |
Rep 4,057
I wonder if using bolts other than titanium could cause corrosion issues.
https://www.monarchmetal.com/blog/ga...ions-answered/ What material is used for the barrel and Center spokes? |
01-18-2024, 10:13 AM | #8 | |
Rep 81
01-18-2024, 11:07 AM | #9 |
Rep 4,057
LOL!!
If the wheels are aluminum, then titanium bolts should be okay, if I am reading the chart correctly at the link above. Post some pics when done - I have a set of the same rims in the garage that my car was fitted with when I got it - so I’d love to see how yours turn out! |
01-18-2024, 01:29 PM | #10 |
Rep 2,547
Since the bolts came out easy/undamaged, I'd have no problem reusing them, the question is, should they get an application of anti-seize, I know that's a no-no for lugs nuts, but titanium into aluminum
01-18-2024, 02:02 PM | #11 | |
Rep 4,057
Toll Free: +1 (877) 832-8209 Tel: +1 (770) 967-9848 Fax: +1 (770) 967-9866 From https://www.bbs-usa.com/contact/?subj=road |
AKDDMD36.50 |
01-26-2024, 10:38 AM | #12 |
Petrolhead
440
Rep 808
Ended up reusing the same bolts. Would prefer to keep the BBS original bolts with the their name stamped on the each bolt. Found out through online search that you should use thread-locker instead of anti-seize and torque to 18ft.lb.
Dropped them off to have the tires mounted this AM. I'll post pics once I have them back.
01-29-2024, 10:56 AM | #13 |
Petrolhead
440
Rep 808
01-29-2024, 07:09 PM | #15 |
Rep 2,547
Those look awesome, I recommend 2 applications of ceramic coat so the dirt just sheds off keeping them clean
01-30-2024, 04:43 AM | #16 |
Rep 125
WOW!!! They look brand new! They will stay that way because of the Akebono brake pads.
I can't wait to do my wheels next. These wheels are some of the best BBS ever did for BMW. My opinion of course.
