      03-14-2022, 01:29 PM   #23
John_Romanos
Drives: BMW Z4 E85
Originally Posted by pungo View Post
Yeah, that huge gap between the hood and the bumper is not normal so something is not right with the bumper. Just so you know, people don't report all accidents to their insurance company so you can't go by a clean record alone, you also need to do a proper inspection by someone that knows what to look for. With you being the 4th owner, who knows the complete history of this vehicle
The topic of this thread is about @3002 tii projector retrofit and since the discussion has has gone off topic, I'm done, unless people want to discuss Bi-Xenon projector retrofits.
Originally Posted by John_Romanos View Post
Nah, that's just lighting. Had the bumper redone because of previous owners (clean title). Original color is titanium silver but was respirated gray for some reason. So now I'm going to go for a fade. Bumper is in crap condition just about because of previous owners scraping on speed bumps and stuff. I have all the info, just not worried about paint right now
Here is a better pic for color
Yeah I'll check it out, i know why its all scrambled up. Thanks for the advice. Still want some headlights, bumper would be nice but $700
      05-09-2023, 11:11 PM   #24
2285
Bump, I like this mod so much that I did this same upgrade today on my recently acquired coupe. This time around I opted for the D2S adapters instead of switching to the Volvo D2R igniters.
The advantage with the adapters is that you don’t have to “modify” the factory plug. However, the downside is the factory igniters need a new location as they still won’t fit in the back of the projector. Luckily there’s more than enough space to wedge it inside the headlight housing. Once you put the cover back on, there’s really no space for anything to move around. So pick your poison…
  1. Volvo D2R igniters >>> Tidy install but need to modify plug
  2. D2S adapters >>> No modification to plug but more stuff jammed inside headlight
Here’s how the adapter connects to projector and bulb retainer. Not shown but the other side (male) would plug into the Hella igniter that would normally hold the xenon bulb.
Lastly if you go this route, definitely affix harness, retainer clip and xenon bulb to projector first before installing the projector back into the headlight.
      05-14-2023, 10:36 PM   #25
pungo
pungo's Avatar
Is this the type cable harness you used? Been having trouble finding these in the US.
      05-15-2023, 08:41 AM   #26
MarinerZ4C
MarinerZ4C's Avatar
43
Drives: 2006 BMW Z4 3.0Si Coupe
Hi 3002 tii,
If I order from RetroFitLab, are they sold as a pair, or priced each ?
Mariner Z4C
2006 Z4 Coupe 3.0Si, Montego Blue, MT
2008 128i Convertible (sold)
2005 325xi Sedan (sold)
      05-15-2023, 12:40 PM   #27
2285
Originally Posted by MarinerZ4C View Post
Hi 3002 tii,
They come as pair.
      05-15-2023, 10:27 PM   #28
MarinerZ4C
MarinerZ4C's Avatar
43
Thanks !
Mariner Z4C
      01-03-2024, 11:00 PM   #29
07ImolaRot
07ImolaRot's Avatar
Drives: 07 Z4M, 05 M3, 13 M3
Thinking about doing this upgrade to my car. Is the EvoX R2 still the one to have?
2007 Imola Red Z4M
2005 Phoenix Yellow M3 6MT
2013 Interlagos Blue M3 6MT ZCP CF roof
      01-04-2024, 06:12 PM   #30
maupineda
Drives: E86 Z4MC
Thinking about this too but I don’t like the idea of stuffing loose components inside the headlight. But for sure my OE projectors are burned off. New bulbs and clear lenses made an improvement but the output is still a bit weak.
      01-04-2024, 06:49 PM   #31
2285
Yep and be sure to replace the bulbs while you’re at it
If you go with the adapters, honestly there not much room if any at all for movement. Or you could go with the D2R igniters which is what I did first time around in my roadster, downside being slight modification to the adapter (equivalent to grinding down a nub). Point being I did both and have no regrets, despite wanting to keep my car as close to “oemplus” as possible.
      01-04-2024, 10:24 PM   #32
07ImolaRot
07ImolaRot's Avatar
which ones do you recommend? I was thinking The osram nightbreakers
2007 Imola Red Z4M
      01-05-2024, 09:45 PM   #33
2285
The Nightbreakers are marginally brighter but it has a more yellow output so really comes down to preference. I went with the CBB and CBI in both my Z since they’re aesthetically more pleasing while still putting out ridiculous amount of light. And for my wife who doesn’t care about looks, she has the Nightbreakers.
Here’s some good review videos that may help
Also I’ve known the owner of Lightwerkz, really standup guy. I would not hesitate buying from them. They ship really fast and have great cs.
      01-06-2024, 11:39 PM   #34
07ImolaRot
07ImolaRot's Avatar
Nice thank you ! The philiphs bulbs look good too. Did you use OEM ballasts?
2007 Imola Red Z4M
      01-07-2024, 12:46 AM   #35
2285
Correct
      01-29-2024, 03:25 PM   #36
rsw1273
Drives: Z4M
Considering doing this mod as well...
anyone consider using the Morimoto D2S 5.0 with a bracket rather than the EvoX-R?
would the D2S adapter along with OEM ballast work with this combo?
      01-29-2024, 04:38 PM   #37
pungo
pungo's Avatar
Is the Morimoto bolt pattern and other dimensions even compatible with Z4 headlight assembly? I put the Morimoto D2S in my Chevy truck, but never compared it to see if they'd fit in the Z4. I'm sure the D2S adapter and stock ballast would work, but the projector itself may not Whereas the EvoX-R for sure bolts right in.
      01-29-2024, 04:48 PM   #38
rsw1273
Drives: Z4M
leaning toward the evox-r just due to the bolt in nature...
however, I had seen someone who had used the D2S 4.0 in the stock headlight with adapter...which made me curious about using the 5.0 version...
There are adapters that allow you to fit the D2S 5.0 to fit the bolt pattern of the E55 style lights (which the EvoX-r is)
Dimensionally the DS2 is actually smaller in size than the EVOX-R...
EvoX-R
Width: 108mm
Height: 96mm
Depth: 157mm
DS2 5.0
Width: 101mm
Height: 88mm
Depth: 143mm
      01-30-2024, 09:35 PM   #39
maupineda
Drives: E86 Z4MC
Height and depth are too far off and can be a problem to achieve the right light output and pattern. Stick to E55 design
      01-31-2024, 07:53 AM   #40
2285
Minor update - I recently swapped out my DRLs and had a chance to revisit my install. If I were doing this install again, I would recommend going with the adapter cables. I noticed the stock wiring in the headlights are beginning to show its age, where some of the wire sheath is slightly exposed or frayed. I guess this is to be expected after 15 years. I recall e39 and e46 owners experiencing the same at some point. The igniter cable is actually one of the more thicker and durable ones so that was actually fine. But it’s just one less thing you need to worry about.
maupineda FWIW there is definitely no slack or moving pieces if you use the adapters. I confirmed this during my DRL swap. With the cable folded neatly and stock igniter wedged in, the outside cover is tight (in a good way), even before you secure the retaining clip.
      02-01-2024, 11:45 PM   #41
solo the lad
solo the lad's Avatar
Drives: E85 Z4
The bumper has some very slight adjustability, if yours is like mine. Just loosen those top bolts and push the top lip back as much as u can, should give u maybe a few mm. Not much but it might do the trick for u
      02-02-2024, 10:24 AM   #42
OneFastMac
OneFastMac's Avatar
21
Drives: 2004 BMW Z4 3.0i
I've looked and looked and this post keeps coming up as the most comprehensive lighting upgrade for E85/86 Z4 but I can't help but notice all the pics are of the "M" and facelift specific headlamps. Will this projector upgrade also fit the standard E85 Roadster bi-xenon headlamp design?
      02-02-2024, 03:47 PM   #43
pungo
pungo's Avatar
The Bi-Xenon headlights are the same for all facelift E85/E86, nothing different about the M vs non-M.
3002 tii2284.50
      02-02-2024, 05:12 PM   #44
OneFastMac
OneFastMac's Avatar
21
Good to know. Since the lights on the E85 non-M roadster only have a single projector lens rather than two lenses in each housing, I wasn't sure if the internal design would be the same.
2004 3.0i manual roadster
