      08-15-2013, 12:54 PM   #221
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Originally Posted by Rated M Roadster View Post
There's no load on the engine though; it happens while shifting or hitting the limiter. AFRs don't matter...
While shifting, I can see that it probably has no issues, but while still on-throttle at the limiter?? Uhhhh..
Well...in any case, I still think this pretty much sums up VF's tune for this kit on my car:
      08-15-2013, 03:26 PM   #222
GuidoK
#buildnotbought
GuidoK's Avatar
10857
Drives: Z4 3.0i ESS TS2+
I think the reason is the same?
It can only build pressure when the TB's are closed and the BOV isn't opened?
It's not the supercharger itself that causes a sudden spike in pressure or boost, it's the fact that the air can't escape so it piles up. And that can only happen when the TB's restrict flow.
So I don't think the revlimiter causes the spike, it's the fact that you (maybe subconciously) lift the throttle. I think the revlimiter only cuts fuel/ignition and not controls the TB's.
      12-11-2013, 10:43 PM   #223
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Thought I would update on how the car is running; have just under 10k miles on the kit and still no problems at all. Still runs amazing and still puts a smile on my face every day! Unrelated to the SC kit though, I just replaced my Vanos bolts (4 out of 6 intake bolts were sheared off); much quieter now.
      12-12-2013, 09:10 AM   #224
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
wow. how many miles on the car? I'm at 76k
      12-12-2013, 12:03 PM   #225
Rated M Roadster
160
Just over 36k miles. Here's a video of the noise that led to the bolts being discovered:
      12-12-2013, 01:11 PM   #226
ZStig
279
ha yeah that definitely sounds off, thanks for posting
      12-12-2013, 02:58 PM   #227
StickMon
StickMon's Avatar
Drives: 2006 MR
About the same mileage where mine went.
Put a new exhaust hub on while you were in there?
That'll go next.
      12-12-2013, 05:47 PM   #228
Rated M Roadster
160
That'll go next.
It looked fine, for now. I have all the tools to do it again though, if need be.
      07-11-2014, 10:52 AM   #229
007M
007M's Avatar
17
Drives: '007 ///M Coupe & Boxster S
I'll get graphs and logs of the new tune when weather permits (got snow yesterday).
Sorry, not too interested in the 1/4 mile. I may eventually get a vbox and do rolling times though.
A little update on my other projects. I ordered some PLX gauges (boost and AFR) and it's an awesome concept, but the actual product sucks; seriously one of the cheapest products I've bought for a while and I'll leave it at that.
As far as the exhaust, my order came in from http://www.mandrelbendingsolutions.com and they sent some of the wrong parts. EDIT: The correct parts should arrive for this weekend.
Hey Rated M,
So, you tried the PLX gauges... what about them did you find cheap? My VF570 install is just finishing up and I'm looking into gauges...
Thanks,
GT
      11-05-2014, 12:29 PM   #230
iTuneCars
Drives: Turbo Lexus
Nice build . You can get more torque out of it with a turbo system. Have you considered a turbocharger system instead?
      11-05-2014, 02:15 PM   #231
Rated M Roadster
160
Everyone knows you can get more torque from a turbo setup and no I haven't considered it cause there have been no successful attempts with a turbo on this ECU (as you've seen with all the turbo threads you've revived).
      11-05-2014, 02:42 PM   #232
Beedub
honestly??? this car and this engine SUITS a supercharger, its perfect for its character. and very in keeping with the original power delivery just moved up the graph, sometimes huge numbers aren't the be all and end all..... my little supercharged z4m was punching well above its weight in my local sprint series this year, we held the number 1 spot for pretty much 80% of the season.... This was definitely in part to the delivery and ease in which it can be deployed.
      11-05-2014, 04:24 PM   #233
Jroc
Drives: Mcoupe
Burned
07 TiAG Coupe
@Jroc561
      11-05-2014, 07:40 PM   #234
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
This.
