      01-19-2009, 09:10 AM   #45
jragan
Imola Lover
jragan's Avatar
As someone who once had the "grind" and learned how to drive the car so as to not grind, try slipping 2nd the slightest bit. I can't tell you for 100% sure what I've changed in my driving "style" that eliminated the grind, but I can drive as hard and shift as fast as I want, breaking the rear tires loose through 3rd gear shifts and I never grind anymore. I do remember trying a number of things, one of which was forcing myself to "slip" 2nd the teensy tinsiest bit.
Hers: 997-1 C4S: Pics
      01-20-2009, 09:10 AM   #46
///mpowah
Drives: 2007 Z4 M Coupe
Thanks for all the replies fella's...
Heres the update: Sent the beast into the local BMW stealer... the clutch was changed.. and WALA.. the shifts are just as good as my M3..
Perfect, with a lovelly wheel spin when changing to second.... YAY!!!!!
Im loving this car!!!!!!!!!!!
      01-20-2009, 09:56 AM   #47
jragan
Imola Lover
jragan's Avatar
Don't get too excited yet...it's a "new" thing so you're subconsciouly driving slightly differently than you were before which is usually all it takes to not grind the gears. Give yourself a week or so to fall back into your bad habits, and then report back if you've ground since...
      01-20-2009, 11:02 AM   #48
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Drives: 997S, MV Agusta F4, E46 M3
Are you redlining a brand new gearbox?
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU
      01-20-2009, 11:22 AM   #49
jragan
Imola Lover
jragan's Avatar
HAHA yeah I read it the same way the first time...he didn't get a new gearbox...just a new clutch.
      01-21-2009, 08:59 AM   #50
reRESERVEDFX
(oO (||||) (||||) Oo)
reRESERVEDFX's Avatar
Drives: 06 BMW Z4 3.0i 03 BMW M5 DINAN
Still, you should let the clutch get a little bit used to the driver for the first 350miles or so.
2006 Porsche 911 C4S Black/Black 6MT/Sport Chrono/Extended Leather/GT2 bucket seats/Turbo wheels
Soon to come 07 BMW Z4M Coupe Black/Red
      01-21-2009, 09:42 AM   #51
jragan
Imola Lover
jragan's Avatar
It does bring up an interesting consideration though...Most have been focusing on the issue being mechanical in nature and caused by the transmission. Could it, instead, be an issue with the clutch or clutch-linkage? It's already been proven on other forums that an aftermarket clutch stop in one car will exacerbate the problem, but if moved to another, "identical" car, there will be no problem at all.
So could it be more of a problem of clutch engagement adjustment such that a decent percentage of the clutches aren't adjusted properly and, instead, have their full-engagement position at or possibly beyond the point of full-pedal travel, whereas it should be a bit before?
Seems logical, but I'm not an automotive engineer (I did, however stay at a Holiday Inn Express last night...)
      01-21-2009, 12:10 PM   #52
Ron Stygar
Drives: 2006 Z4 M Coupe
SAC Clutch break in
