      08-29-2016, 04:43 PM   #1
Shorts
Drives: E86 M coupe, E91 325xi
Z4MC seat belt replacement
Hey guys,
I am looking to replace my lazy passenger side belt as it does not want to retract. I have already dismantled my trunk area once to install a Mediabridge unit and would like to avoid that hassle again. Have if any of you done this? Is the seat belt accessible from behind the seat? I am wondering if I can get to it by disassembling the plastic trim around the sub.
Thanks!
Ryan
      08-29-2016, 05:40 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
The belt reel is behind the rear bulkhead.
You need to remove the trims in that area
      08-29-2016, 10:54 PM   #3
pcube
pcube's Avatar
58
Drives: Z4MC, G20 320i
No need to dismantle the trunk. Get the rear roller sun shade removed and you will be able to access both seat belt assemblies simply by pulling back the carpet.
      08-30-2016, 09:39 AM   #4
Shorts
Awesome, thanks guys
      09-06-2016, 02:08 PM   #5
Beedub
i wish it was this easy on the roadster!
      09-07-2016, 07:55 AM   #6
Blakkflame
Blakkflame's Avatar
Italy
44
Drives: Z4M - E91 MSport
......do you love them in blue or red ??!?
      05-07-2017, 05:35 PM   #7
Shorts
Hey guys I have finally gotten around to trying this and have hit a road block. Before I attempt to take anything else apart I thought I would seek some guidance from you. I need to remove the passenger side seat belt and have removed the B pillar cover, the trim piece directly below the B pillar and the trim piece directly above the center console.
Can you please advise on next steps? This is where I'm at: (Please excuse the dusty interior, a full detail is pending this install )
https://drive.google.com/open?id=0B5...Wp6U2hwZHo1VVk
Thanks in advance! Much appreciated!
Ryan
      05-07-2017, 06:06 PM   #8
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
You need to remove all the trim across the top in order to get the tonneau cover roller out.
Once that's out you're good
      05-07-2017, 06:44 PM   #9
Shorts
Do you know how the small trim pieces around the seat belt come off?
      05-07-2017, 08:41 PM   #10
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Its been a while but IIRC, Its two pieces
one part you have to pry off with a trim tool,
the other is bolted
      05-08-2017, 01:41 PM   #11
Steeler
Steeler's Avatar
2428
the other is bolted
Correct, pry up on the curved cover piece. Item 10 below.
http://www.realoem.com/bmw/enUS/show...diagId=51_4916
      05-08-2017, 11:28 PM   #12
Shorts
Thank you. I will have another go at it this weekend
      06-24-2017, 11:36 AM   #13
Shorts
So I finally got around to doing this, your tips on getting the interior trim apart were very helpful, thank you.
Turns out the belt was just twisted below the trim piece so I didn't need to replace it! It's all back together now and working in good order.
Thanks again guys!
