      06-03-2014, 02:06 AM   #1
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
What's this squeal on start up? Belt, pulley, something else?
So during cold starts my 2004 3.0i makes make loud squealing noise. Any idea what it could be?
      06-03-2014, 10:10 AM   #2
MinneapolisJeff
Drives: 2003 BMW Z4 3.0i
I have a similar sound occasionally; I think it is the starter recoil?
the stable:
2003 BMW Z4 3.0i
2020 Mitsubishi Outlander SE
2021 Jeep Gladiator Rubicon
      06-06-2014, 12:13 AM   #3
psygnosis
psygnosis's Avatar
23
It's every day and I replaced the starter not too long ago.
      06-06-2014, 07:22 AM   #4
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
jesus thats a nasty noise. I would also guess starter. I assume the noise was present both before and after you replaced the starter?
Maybe its a belt or pully thats getting stuck on start up, and the rest of the pullys turning kind of yanks the belt and makes that noise?
      06-06-2014, 08:44 AM   #5
psygnosis
psygnosis's Avatar
23
No the noise is recent, I replaced the starter a little while ago when what ultimately tuned out to be a bad key.
      06-06-2014, 01:19 PM   #6
MinneapolisJeff
the only other thing I replaced with respect to belts/pulleys was a worn out mechanical belt tensioner and that sound was different than this
the stable:
2003 BMW Z4 3.0i
      06-06-2014, 01:44 PM   #7
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I would check alternator and power steering pulley. Check power steering fluid level. Also check water pump bearing. I had similar noise and thought it was the alternator pulley because I installed an old alternator. A few months later, my water pump when out.
