04-24-2008, 08:56 PM | #2 |
My favorite sign.
169
Rep 4,333
Good luck
04-24-2008, 09:52 PM | #3 |
Rep 1,191
welp it's done. NO bulb out warning light or anything. Flash to pass works, i have BOTH high beams, walk me home function are all the same.
Halogen Headlight with projector in pic without the projector Halogen Cut Off Bi-Xenon Cut off Everything in place Beam Pattern on Bi-Xenon LOW BEAM High Beam(bi-xenon PLUS high beam) looks like a upside down U Halogen VS Bi-Xenon NO difference in lens...little different cut off but hard to tell the difference
2022 GLE 53 Coupe
04-25-2008, 09:44 AM | #6 |
Rep 1,191
i only swapped out the projector. I had aftermarket HID's already then just used D2S to aftermarket ballast converter.
remember BROWN is negative any other color is positive on headlight.
2022 GLE 53 Coupe
04-27-2008, 09:39 AM | #11 |
Rep 259
Am I correct is assuming the reason you did this was to allow you to use the factory D2S bulbs? Does the bulb socket appear to be the main difference in the two projectors? I have the MTEC setup (I think that's what you had). Where did you get your aftermarket D2S converter? How did you get the cable out of the housing? I had to drill a hole through the cover for my MTECs.. Now you need to add the auto-leveling... that would be cool... Chuck
04-27-2008, 10:19 AM | #12 |
Rep 1,191
I don't have M-tec...and I didn't spend $300 on it either
bulb holder is different...duh it's different for EVERY BULB. D2S converter avail on ebay. drilled a hole as well auto level...not possible. No way. It requires sensors, motors, wiring, and etc to make it work. If i remember, someone tried to lower a car with auto level lights and it really messed it up because of that height difference
2022 GLE 53 Coupe
04-27-2008, 03:55 PM | #13 |
Rep 166
Wow, I think this post jinxed me or something.... Now one of my headlights isn't working. The left side light works fine, but the right side doesn't turn on and it throws the bad bulb code in the dash. Looks like the bulb is fine, so I donno what the problem is. Could be a dead computer canceller, or a bad ballast maybe?
01-18-2010, 01:49 AM | #14 |
Rep 17
Drives: 2004 Alpine White BMW Z4
Bringing up a post from the dead.
Nice retrofit. Question, you did not get any bulb out error codes? Smidley, did you ever get yours fixed? I'm thinking of buying the DDM Tuning 55w 6000k HID kit ($60) but I don't want error codes popping up. http://www.ddmtuning.com/index.php?p...parent=85&pg=1 |
01-19-2010, 06:49 PM | #16 |
Rep 393
Drives: E86 Z4 M Coupe
Garage List MK4 VW GTI 1.8 Turbo [0.00]
MK1 VW Rabbit GTI ( ... [0.00] E90 335i sedan [0.00] E86 Z4 M Coupe [7.50] E36 325is (Track Car) [0.00] |
great job
06-03-2014, 03:33 AM | #17 | |
Rep 54
To power the ballasts, did you get power from the wiring inside or outside the headlights? I hooked up my ballasts to the low beam's wiring inside but they did not light up. |
