      05-14-2014, 02:42 AM   #1
mtrhed
mtrhed's Avatar
13
Drives: 06 AW Z4MR/w211 e63 AMG/325XiT
SuperFlex Urethane offset FCABs
Finally got around to installing them. Look to be well made and install was a breeze. Steering is a bit sharper and rock solid under heavy braking. Now, if they hold up longer than the stock units I will be very happy! I also broke down and got the Bimmerworld spherical sealed bearing RTABs. A bit spendy but I am sick of spending time changing out the stock units. I should have them in a week or so and will review them after I get them installed. If they are anything like the Dinan monoball units I had on my e39 M5 it will be money well spent and at less than half the price of the Dinan units. I think I only got about 12k miles on the last set of stock RTABs before I could feel the rear end getting a bit wandery. If CA would just start fixing more of it's secondary hwy's my suspension would last longer! How are the roads in Texas???
06 Alpinweiss Z4M R
Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake
      05-14-2014, 08:25 AM   #2
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Unfortunately not much better. Hit one hell of a pot hole this morning. Wasn't able to dodge due to traffic but atleast I was able to slow down.
      05-21-2014, 11:13 PM   #3
unluky
unluky's Avatar
7528
I have had my sites on doing my control arm bushings as well. Are the super flex the ones to go with? I don't mind some extra feel, as long as it is not harsh. I did the full urethane swap to my 300zx and liked it, so I assume this would be a similar feel change. I did not want to go OEM if there was a better option.
How tough is the rear trailing arm bushing to swap?
My car has always been a little "wandery" with a neutral wheel. Ditching the run flats were 90% of it! but I still have more than I think I should. My 1990 z is tighter, so that tells me to keep looking. These were on my list to do. Car is a 04 with 60k and while it seems to have been well taken care of, everything I am looking at it still factory installed. May need to look at the rtab's as well. Is there a go to bushing here?
Thanks for any info, trying to work my way I to this.
      06-03-2014, 03:08 PM   #4
mtrhed
mtrhed's Avatar
13
Sorry, didn't see these replies.
So far I am very happy with the SuperFlex fcabs. A few other members on this board have had them installed for quite awhile and seem to only have positive things to say about them. I think I just solved the last piece of the puzzle for my suspension with the spherical ball joint rtabs. Stock rtabs with limiters is a good way to go also. I just wanted less movement and hopefully better longevity.
06 Alpinweiss Z4M R
      06-07-2014, 11:58 AM   #5
macsubie
Drives: 06 Z4 MC
hi
may i know which one did you buy?
I was looking up on their website and I couldn't find one is for ZMC or ZMR.
Thanks!
Mac
      06-07-2014, 03:48 PM   #6
mtrhed
mtrhed's Avatar
13
Listed as for the e46, but work for the z4m also.
http://www.superflex.co.uk/proddetai...od=SF095-2558K
06 Alpinweiss Z4M R
      03-10-2016, 05:58 PM   #7
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
guys, I ordered FCAB from superflex, and they shipped through royalmail....Its impossible to find where to contact them.
The tracking number shows that the item arrived in LA on 3/4....its been 6 days that has arrived in US....is this normal?
      03-10-2016, 06:05 PM   #8
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
nvm....just put the tracking number on USPS and it shows is being delivered tomorrow.
      03-10-2016, 06:07 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
2 days to get from UK to LA through royalmail, a week to get from one part of LA to another part of LA through USPS.
