      08-02-2009, 04:51 PM   #1
m44rrt
Drives: z4
z4 Aluminium dash replacement
I have just bought a 2004 3.0 SE but the aluminiun dash, strip around the gear lever and door grabs are all scratched.
I have bought, via ebay, a BMW replacement set of new aluminium parts.
No fitting instructions.
Anybody done similar replacements and can provide fitting instructions or useful tips?
Much appreciated
Martin
      08-02-2009, 10:48 PM   #2
jra
Drives: 2005 z4
not hard at all, if you need any info send me a pm
http://www.motortribe.it/community/f...ad.php?t=17410
http://www.motortribe.it/community/f...ad.php?t=17411
      08-03-2009, 11:12 AM   #3
3002 tii
3002 tii's Avatar
2282
i did the same swap when i replaced my wood for aluminum. the front dash is easy enough, it's the center console that's a pain in the arse. only concern was that the replacement dash doesn't come with those clips so you have to reuse your stock ones, but they easily fall out when you remove the stock pieces, and once they fall out, ure screwed... no way you'll be able to retreive them behind the dash.
Follow for latest mods
      08-03-2009, 04:19 PM   #4
m44rrt
Drives: z4
Thanks for the link
Is there an english version? Italian is interesting.
Google does an ok translation but some images are missing.
Martin
      08-03-2009, 05:22 PM   #5
Spaceman Spiff
Drives: R8, 996 C2, Z4MR (sold)
I haven't seen an English version but when I swapped mine I didn't even need the translator. The pics are self explanatory and I don't think the missing ones should cause you any trouble (maybe showing the clip behind the right end of the dash trim). Also, for the center console (since I have removed that several times before for nav retrofit and trim change) you don't need to take off the shift knob, which is kind of hard. Just pull up the boot cover and slide the cover through the hole in the console.
      10-03-2009, 11:59 AM   #6
GLF
GLF's Avatar
Drives: Z4, 3.0si SILVER
I had to remove just the dash to install start button. The clip on the right end takes some patience other wise the dash portion is easy.
Here is a shot with it apart
ALWAYS GO TOPLESS
      11-08-2009, 01:56 PM   #7
SSG S
Drives: DINAN Z4
Originally Posted by jra View Post
Im having trouble removing the center dash~!!! Since the guide is missing pictures im not sure what im missing here ;( Can anyone help? Thanks guys.
SSG S
      11-08-2009, 08:23 PM   #8
Oryx33
Ghostrider
Drives: Z4 2.5i Sport
Same problem here. Removed the Dash panels and door handles no problem at all using the guide. But the guide for the panels covering the transmission tunnel are missing a few steps not to mention inaccurate as far as removing the storage compartment door is concerned in my case. If anybody has abetter guide it would be much appreciated.
Z4 2.5i sport package, Imola red, SMG, 18" MSW type 16's, Custom magnaflow system
      10-18-2015, 01:49 PM   #9
Forbes
Daily driver/Weekend mechanic
Forbes's Avatar
Drives: '06 Z4 3.0i Roadster
2006 Z4 3.0i  [6.00]
2014 BMW 328i  [0.00]
I like the brushed aluminium trim. It adds character. My '06 3.0I came with silver painted plastic which I swapped out in favour of an aluminium set I got of ebay. When doing the tunnel be careful with the trim disks covering the 4 nuts adjacent to the seats. I broke 2 of mine. Replacements from BavAuto were not only way expensive, but they were born tan and spray painted black - same thing from getbmwparts.
      10-18-2015, 02:59 PM   #10
NickyC
NickyC's Avatar
17454
The only hard part is that mother!#!#$ clip on the right hand side of the console. It's one of those things where if you know how to operate it, it comes off like magic. If not, you'll be cursing the car for at least an hour. How do you think my first time with it went? ;D
      10-18-2015, 10:04 PM   #11
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Lemme guess Nicky
Powered by
      10-19-2015, 10:59 AM   #12
NickyC
NickyC's Avatar
17454
Originally Posted by Vanne View Post
Lemme guess Nicky
I had to resist every urge in me to not just PULL the damned thing off the car, lol!
I didn't even bother reinstalling it (the clip) once I put the dash back in place. I haven't noticed a difference regardless.
      04-13-2016, 12:09 AM   #13
kav
Drives: Z4M
I'm about to take on replacing my aluminum dash trim. Have there been any other instructions discovered for this?
      04-13-2016, 08:45 AM   #14
Steeler
Steeler's Avatar
2428
Remove the vent by inserting 2 flat blades between the top of the vent and the dash plate to release the clips(I used 2 putty knives) and it will slide out.
Remove the 2 screws that hold the radio in place and slide out enough to disconnect the antenna and the wiring harness. The harness has a bale on it that you have to squeeze and rotate to unlock the harness.
There are 4 Phillips head screws behind where the radio and vent was. 2 on top and 2 on bottom of the cavity.
Once all that is done grab the dash inside the cavity and tug. If it has not been out before it will be tough but keep tugging it will come.
If you need to "force" it off put the putty knives between the dash and the dash plate and pry gently.
As Nicky said the clips are a pain and most if not all will fall off inside the deep dark dash cavity.
I used an extendable handle magnet to retrieve them.
      04-13-2016, 01:45 PM   #15
kav
Drives: Z4M
Thank you!
I was hoping more had been found in the way of diagrams and pictorials.
      04-13-2016, 02:12 PM   #16
Steeler
Steeler's Avatar
2428
Sorry, not much of a pic taker.
Fairly simple process if you follow what I described.
      04-13-2016, 03:30 PM   #17
kav
Drives: Z4M
Do you have directions for the centre console and other little piece?
      04-13-2016, 03:45 PM   #18
Steeler
Steeler's Avatar
2428
I have removed and replaced the entire interior in the past but did not care if I broke anything during removal as it was absolutely shot from the Fla sun.
Search on the interior portion of this forum. I believe there are some threads on there.
      04-14-2016, 07:12 AM   #19
SDCoupe
SDCoupe's Avatar
78
Drives: M Coupe
Has anybody tried swapping to the carbon leather dash? Those even available?
      01-12-2017, 09:20 PM   #20
abelgonzaleZ4
Drives: 2006 BMW Z4 SilvrConvert 3.0i
Any instructions in English?
      01-12-2017, 09:23 PM   #21
abelgonzaleZ4
Can you help me do my Center console tunnel trim?
Any directions would be appreciated. I'm doing the same, swapping my wood for brushed aluminum
      01-13-2017, 08:50 AM   #22
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Subbing for info on removal of dash
Tags
aluminium trim, dashboard
