06-16-2011, 09:00 AM | #23 |
Bad Lieutenant
233
Rep 3,517
Sounds like something else, man, that thing was beefy. Did they have a max rating for it?
06-16-2011, 10:05 AM | #25 |
Certified Adrenaline Junkie
43
Rep 1,325
06-16-2011, 12:34 PM | #27 |
Bad Lieutenant
233
Rep 3,517
Yeah, forgot you had to replace that as well; the OEM bearing must count on some amount of slop, which you've taken care of with the other mods.
06-16-2011, 12:38 PM | #28 |
Rep 2,460
all mounts motor tranny and guibo have been upgraded.....been on the phone all day with different parts of the US to try and make a polyurethane stamped driveshaft bearing so i can run that while i wait for my carbon fiber driveshaft......annoyed is what i am right now
06-16-2011, 12:40 PM | #29 |
Rep 2,460
oem rubber on these cars is retaredly stupid and prone to failure.
whats worse is due to the rare nature of the car we cant get awesome aftermarket parts for the little things like this because our production numbers are waaay under 10k units on the planet |
06-16-2011, 02:10 PM | #30 |
Rep 170
Your issues really don't sound like a Guibo or support bearing related.
Sounds to me like either driveline misalignment or excessive diff (tranny)movement. I can understand that the Guibo and Bearing may fatigue in time, but the fact that your support bearing failed so quickly mean there is a lot of driveshaft movement. I would check the angle of the Tranny vs. Driveshaft and make sure you diff/ diff carrier don't have any excessive play. |
06-17-2011, 01:58 AM | #31 |
Rep 2,460
i just rebuilt my hanger bearing thingy using hot glue because of its very tough and flexable nature when cooled......then i sprayed black header paint over it.....will post pics
06-18-2011, 07:14 PM | #34 | |
Rep 2,460
because i have a near new clutch and flywheel, im putting way too much snap to the ground....i was able to shear some clearance around the yoke side bolt carriers....i swapped in a stock guibo from turner and a stock driveshaft bearing....and i will try to properly break in the clutch. epic |
06-18-2011, 07:23 PM | #35 | |
Bad Lieutenant
233
Rep 3,517
06-18-2011, 09:25 PM | #36 |
Rep 2,460
i think the stock guibo is awesome after everything ive tried....hanger bearing on the D/S.....not so much....i will be sending off a perfectly new D/S hanger bearing so that it may be duplicated in such a manner where all the rubber pieces that BMW provides us can be reverse "iron manned" into polyurethane
11-23-2011, 02:16 PM | #37 |
Rep 1
I have a similar (5L40E) transmission with exactly the same output flange, that I'm swapping into an old Tr4, and I just don't understand how the flex disc attaches!!! The output flange is a shallow circular cup with 6 tapped holes, just like in your photos. But the flex disc only attaches using 3 bolts on each side. The yoke on the drive shaft side has 3 legs and 3 bolts. How does the flex disc attach to the transmission flange? I know this must sound stupid, but what am I missing?
04-20-2012, 09:11 PM | #39 |
704
09-13-2012, 09:37 PM | #42 |
6 of Diamonds (ret)
82
Rep 566
I missed the fix - So in the end was it just a new clutch and lots of enthusiasm?
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
