      06-07-2016, 10:17 PM   #45
crfine88
crfine88's Avatar
438
Drives: E86M
Originally Posted by itdnwiwbp
Originally Posted by fdagen View Post
Yes it has been resolved
Did you guys get a tune that resolves the rpm dip?
I have been running the latest tune for a couple hundred miles in the AZ summer heat and I haven't had this issue
Mtxzptlk871.00
      06-08-2016, 06:16 AM   #46
No_Dominion
No_Dominion's Avatar
117
Drives: 2007 Z4M Coupe
Good, glad to hear it.
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides
DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake
MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS
      06-08-2016, 08:52 AM   #47
itdnwiwbp
Drives: 330iZHP
Great! Thanks! Seems I need to get in touch with Evolve for an update. I do wish they'd just send each update to everyone running their box...
      06-10-2016, 12:10 PM   #48
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I never receive a new tune. Guess I have to email them.
Edit: I email Evolve and they me the updated tune the next day.
      06-18-2016, 03:54 PM   #49
itdnwiwbp
Drives: 330iZHP
I got the updated "final" tune from Evolve as well and loaded it today. On the test drive the rpm stumble was far less frequent but two of the three times that it happened it was severe, dropping to 500rpm. I also cleared codes before the drive and check after. No SES but it did have two 0000s and 2F65.
      06-22-2016, 04:20 PM   #50
RobMCoupe
RobMCoupe's Avatar
60
I flashed it last week but have not driven the car yet. I read for fault code but none exists but SES light was on. There are 4 instances of 2FDA as I recall. The "0000 No Fault Code description found !" is not present. I was going to read for fault code again but ran out of time. It will be another two weeks before I can drive the car. I stripped all polishes with Dawn to prep for claying my car. Office called and need to attend an emergency issue. The car been sitting in garage since. So need to polish the car before checking if new tune is a keeper.
Edit: On the stumbling issue. I redo my IAT wiring to make sure it connect to same color when tap into MAF wiring. It was one of the steps troubleshooting SES light. I noticed the car ran a bit better and don't stumble as bad like it would go down between 700rpm and 800 rpm.
      04-03-2017, 06:41 PM   #51
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
871
Drives: 635/1815, X3M Comp
Reviving this thread as my current experience from a recent install relates to this.
- 100 miles since install
- No SES light
- 3 trouble codes (confirmed no codes prior to install)
Anyone run into the same thing and was able to resolve?
Thanks,
      04-04-2017, 08:53 AM   #52
itdnwiwbp
Drives: 330iZHP
I think pretty much everyone has this issue.
      04-04-2017, 01:04 PM   #53
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
871
itdnwiwbp, Thanks for the response.
Are those codes enough to fail an OBD smog test?
      04-06-2017, 05:50 PM   #54
RobMCoupe
RobMCoupe's Avatar
60
My check engine light was on so definitely will fail smog. The latest software fixed this issue. My check engine light have not return since the latest software was flashed.
      04-07-2017, 09:20 AM   #55
itdnwiwbp
Drives: 330iZHP
Same here. No CEL since the final tune. The codes are present but I don't know if they'd cause a failed smog test (if there's a blind tech performing the visual).
      06-17-2017, 04:37 PM   #56
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
871
Just to a give an update and FYI on this... the codes will trigger a monitor to come on hence the car will fail smog.
I had a local indy shop that does maintenance on my car check... Box had to come off, revert back to a stock tune, ran some miles to pass smog. Kind of annoying to have to go through that. =(
      06-17-2017, 09:28 PM   #57
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Sorry to hear that, I'd keep bugging evolve about it mate, you can't just keep pulling your airbox off every year you have to do smog. That would suck hard.
      06-23-2017, 04:14 AM   #58
tikamak
Lebanon
58
I have the same issue with an ESS supercharger
      04-18-2020, 06:25 PM   #59
maupineda
Drives: E86 Z4MC
FWIW I have a Karbonious Box with an Epic Tune and...
I don't have an idle issue and the RPMs never dip, however, I do have the three codes some mentioned
0000 Error location not marked
2F65 Brake booster, system check
2FDA crankcase ventilation, system check
I think this is just the nature of the mod, the car drives perfectly fine and I have no check engine light on, I assume the tune just masks it.
Search this Thread:
Advanced Search
