05-07-2016, 10:04 AM | #3 |
dances with roads
4722
Rep 4,096
N52 Z4 aftermarket exhausts are exceedingly rare. Most folks go homespun.
Heftier rear swaybar sounds like a recipe for spinning off the road backwards (track rats go so far as to disconnect the rear swaybar entirely). AFE sells an intake. http://afepower.com/shop/details_new...artno=54-11602 Can't comment on the camber plates. |
05-08-2016, 07:09 PM | #4 |
Rep 2,704
Check out magnaflow and Supersprint
Magnaflow http://www.hottexhaust.com/Magnaflow_51725 SS http://www.schmiedmann.com/Z_series/...ge6.htm#paging item 788106K
05-08-2016, 07:44 PM | #5 | |
Rep 12,565
05-09-2016, 09:01 AM | #7 |
Rep 12,565
Primaries yes
But you also have secondaries (not hooked up to any sensors) in the catback section. If you know you're going to go catless, I would keep secondaries. If you don't want to bother with catless (needing a tune, dealing with emissions), then chopping off the secondaries is fine. For a street car I'd do the latter, and do a single merge like I linked above or just get the SS exhaust that does the same. For bump in "power", I'd switch up the final drive to a 3.73 auto (assuming you got manual). |
05-09-2016, 10:25 AM | #8 |
Rep 2,704
OK I see.
I used the MF on my 3.0i with some modifications B/C I needed cats. Sorry OP for the hijack. At least you are getting bumped up :>)
05-16-2016, 07:18 PM | #9 | |||||
E86 M Coupe
265
Rep 403
Thanks for your reply!
No problem thanks! |
05-20-2016, 12:31 PM | #10 |
E86 M Coupe
265
Rep 403
Looking for additional parts. OP edited to what I am searching for.
08-02-2016, 01:34 AM | #11 | |
Rep 310
Bigger rear bar, also shocks and springs
Bigger bars: Have 22.5mm MCoupe rear bar and 27mm MCoupe front bar.
Also set of M Coupe springs and rear shocks. Good exhaust will be an 2.5" X pipe in place of the resonators, then into a dual 2.5" inlet single 3" outlet Flowmaster series 50. Great flow increase, no boat sound or obnoxious rattiness, just low pitch and a bit louder than stock. Did it on M54 3.0 liters with great results. Quote:
And you may ask yourself, "Where is that large automobile?"
09-22-2016, 11:46 PM | #12 | |
E86 M Coupe
265
Rep 403
Thanks for the info! Much appreciated! Bump!
