      05-04-2016, 10:12 PM   #1
pelerojo
Drives: '06 Z4M
WTB Z4M Front Struts
Looking for a right front or a set of front struts from a 06-08 Z4M with less than 35k miles. Pm if you happen to have a set for sale. Thanks.,
      07-03-2016, 11:12 PM   #2
MCPilot
MCPilot's Avatar
Drives: 2013 E92 M3
Do you still need these? I have a set from an '08. I think I had 10-15K miles on the car when i switched to coil overs.
|ST BBK|KW Competition|Formula 43|Dinan Intake-Pulley-Exhaust|R888|Schroth|BPM|UUC-SSK|UCP|Turner|Racing Dynamics|RRT|
      07-13-2016, 05:22 PM   #3
mpathic
Drives: Z4 MCoupe,3.0Si R,E61 535xiT
Have two sets here, both from MCoupe, stiffer valving. Approx like a Koni on 1/2 turn rebound. Rear shocks like Koni DA set to 3 clicks bump and 1/2 turn rebound. This is really nice compared to other BMW model stock struts and shocks.
One set of struts 45k, other set 75k, w/ or w/out springs, upper mounts and bearings. $125/pair. Add $75 for the pair of shocks. Also MCoupe front 27mm bar and 22.5mm rear bar, M Coupe springs. Noticeable stiffer front than MRoadster, rear feel slightly stiffer but might be equipment variations rather than a straight Coupe vs Roadster spring rate difference.
And you may ask yourself, "Where is that large automobile?"
